21616 Discussions
not able to detect any instance for core < hps_sdram_p0 >
I'm trying to get into a Cyclone V based evaluation board (EBV SoCrates). While already getting LEDs to blink, on pure FPGA side, now I wanted to do a setup with QSYS. I took the "default clock", a "hard processor system" and created a "custom" component to combine it with one of my vhdl files. Another VHDL file is not in the QSYS setup. I compiled the QSYS and I integrated the resulting .qip into the project, together with the other .vhdl file.
Finally, I adjusted the toplevel VHDL file, but there seems to be something missing. After setting the LED pins and one clock pin (the same I used before). At compilation then, I get the following:
--- Quote Start ---
Info (332104): Reading SDC File: 'soc_system/synthesis/submodules/altera_reset_controller.sdc'
Info (332104): Reading SDC File: 'soc_system/synthesis/submodules/hps_sdram_p0.sdc'
Info (332151): Clock uncertainty is not calculated until you update the timing netlist.
Error: The auto-constraining script was not able to detect any instance for core < hps_sdram_p0 >
Error: Verify the following:
Error: The core < hps_sdram_p0 > is instantiated within another component (wrapper)
Error: The core is not the top-level of the project
Error: The memory interface pins are exported to the top-level of the project
--- Quote End ---
What is wrong here? What is meant by "hps_sdram_p0", I did not write a component by this name - where can I look this up?
I tried to verify the items, but I'm completely unsure. How can I check if hps_sdram_p0 is instantiated within another component?
The .qip (supposed it is meant by "core"), is definitely not the toplevel. I assume the "memory interface pins" as main cause, since I did not set anything here. But - which memory inteface pins, do I need? Where to look up what is required, in order to check its address in the processor's datasheet??!
Hi again, I think I found a solution to my problem, my fix was
1) run "start analysis & synthesis", once to read the information, then
2) in "Tools" -> "TCL Scripts...", run the script <my system>/synthesis/submodules/hps_sdram_p0_pin_assignments.tcl
3) and then running the compilation
PShar32
hi,..
  I was suffering the same .. and I followed the steps you provided.. and when I run TCL scrip I get error like.
Error:Error: The core < hps_sdram_p0 > is instantiated within another component (wrapper)
Error:Error: The core is not the top-level of the project
Error:Error: The memory interface pins are exported to the top-level of the project
Error:Error: Alternatively, if you are no longer instantiating core < hps_sdram_p0 >,
Error:Error: clean up any stale SDC_FILE references from the QSF/QIP files.
Error:Info: Dumping reference pin-map file: hps_sdram_p0_all_pins.txt
Error:Error (23031): Evaluation of Tcl script F:/<----->/synthesis/submodules/hps_sdram_p0_pin_assignments.tcl unsuccessful
Error:Error: Quartus Prime TimeQuest Timing Analyzer was unsuccessful. 8 errors, 3 warnings.
But when I delete the <hps_dram_p0.sdc> from /synthesis/submodules I see no error in main compiler..... !
but it shows some error when i use nios II fast core.. like
Error (210039): File F:/micro_pmu_structure_01/output_files/micro_pmu_daq_time_limited.sof contains one or more time-limited megafunctions that support the Intel FPGA IP Evaluation Mode feature that will not work after the hardware evaluation time expires. Refer to the Messages window for evaluation time details.
