Programmable Devices
21615 Discussions
not compiling
hello all
i wrote down this simple divider code and for some reson it wont compile- it gives me the
No feasible entries for infix operator "/"
thats the code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
entity div is
generic (N : positive );
port ( a : in signed(N-1 downto 0);
b : in signed (N-1 downto 0);
div_res : out signed(2*N-1 downto 0)
end entity;
architecture behave_div of div is
begin
div_res<=a/ b;
end behave_div;
thanks
There are three issues involved with this short code snippet.
- a trivial one: the VHDL divide operator is slash '/' rather than backslash '\'
- an arithmetic one: the quotient must have the same length as a
- a VHDL library related one: std_logic_arith doesn't infer divider for signed type, you need to use numeric_std instead
P.S.: This code compiles correctly
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity div is generic (N : positive := 8 ); port ( a : in signed(N-1 downto 0); b : in signed (N-1 downto 0); div_res : out signed(N-1 downto 0) ); end entity; architecture behave_div of div is begin div_res<=a / b; end behave_div;
thaks, its working
why cant i use 2N vector as the quantiet?it is long enough for the reult to fit in.
It is more than long enough... but if you really want to have twice the required amount of bits, I suppose adiv_res <= resize(a/b,2*N);should do the trick.
hi,
the divider compnenrt is working well, the thing is that i am tring to put it under another compnenet, the other componenet is using the arith.all library.
all the files go throgh complition, but as i am trying to run the testbench on modelsim i get an error saying that "# ** Failure: (vsim-3807) Types do not match between component and entity for port "a".
" for all compnenet ports, i have checked both the packege file and the enttity file' where types are defined and they are all set corectlly. do you know i get this error and how can i overcome it?
thanks
The way round this error is to use either std_logic_arith package in all files, or the numeric_std package in all files. Mixing the two will give you the problems you are getting.
I highly recommened switching to the numeric_std package - it is a IEEE standard - std_logic_arith is NOT.
