hello all
i wrote down this simple divider code and for some reson it wont compile- it gives me the No feasible entries for infix operator "/" thats the code: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_signed.all; entity div is generic (N : positive ); port ( a : in signed(N-1 downto 0); b : in signed (N-1 downto 0); div_res : out signed(2*N-1 downto 0) ); end entity; architecture behave_div of div is begin div_res<=a/ b; end behave_div; thanksLink Copied
There are three issues involved with this short code snippet.
- a trivial one: the VHDL divide operator is slash '/' rather than backslash '\' - an arithmetic one: the quotient must have the same length as a - a VHDL library related one: std_logic_arith doesn't infer divider for signed type, you need to use numeric_std instead P.S.: This code compiles correctlylibrary ieee;
use ieee.numeric_std.all;
entity div is
generic (N : positive := 8 );
div_res : out signed(N-1 downto 0)
end entity;
begin
div_res<=a / b;
end behave_div;
thaks, its working
why cant i use 2N vector as the quantiet?it is long enough for the reult to fit in.- Mark as New
It is more than long enough... but if you really want to have twice the required amount of bits, I suppose adiv_res <= resize(a/b,2*N);
should do the trick.
hi,
the divider compnenrt is working well, the thing is that i am tring to put it under another compnenet, the other componenet is using the arith.all library. all the files go throgh complition, but as i am trying to run the testbench on modelsim i get an error saying that "# ** Failure: (vsim-3807) Types do not match between component and entity for port "a". " for all compnenet ports, i have checked both the packege file and the enttity file' where types are defined and they are all set corectlly. do you know i get this error and how can i overcome it? thanks- Mark as New
The way round this error is to use either std_logic_arith package in all files, or the numeric_std package in all files. Mixing the two will give you the problems you are getting.
I highly recommened switching to the numeric_std package - it is a IEEE standard - std_logic_arith is NOT.
