21593 Discussions
one shot and D flip flops
Greetings.
What is the advantage of putting one shots (one clock pulse if the D in a flip flop goes high) and basic D flip flops in designs? I see them placed in a lot of designs I look and and wonder if there are certain rules experienced designers use for them. When would be a good time to use a "Oneshot" or a "D flip flop"
using the outputs of logic/registers as clocks is a general no-no in FPGAs. You CAN do it, but unless you get the "clock" into a clock net you're going to have timing problems.
Its best to use clock enables (and much less complicated and much easier for another engineer to understand.)
What is then the best use for D flip flops in a design?
thanks for the reply
basically everything involving a clock. They create the pipeline
D types are the basis of all designs. You can use clock enables to move data along the pipeline or not.
