21615 Discussions
permission error accessing fpga aria 10
joeryan
I am getting errors running fpgabist when logged in as an unprivileged user, but it works when using the root account.  Additionally, I see permission denied errors in an strace when attempting to use aocl for any purpose.  The permissions look correct based on the changes made by AOCL_BOARD_PACKAGE_ROOT/linux64/libexec/setup_permissions.sh.  I am unable to run aocl commands under root user until I determine all the necessary environment variables/path updates needed to successfully run them.  This is installed in a shared environment, so unprivileged users would need access to use the cards.
$ ll /dev/intel-fpga*
crw-rw-rw- 1 root root 242, 0 Sep 14 12:51 /dev/intel-fpga-fme.0
crw-rw-rw- 1 root root 242, 1 Sep 14 12:51 /dev/intel-fpga-fme.1
crw-rw-rw- 1 root root 242, 2 Sep 14 12:51 /dev/intel-fpga-fme.2
crw-rw-rw- 1 root root 241, 0 Sep 14 12:51 /dev/intel-fpga-port.0
crw-rw-rw- 1 root root 241, 1 Sep 14 12:51 /dev/intel-fpga-port.1
crw-rw-rw- 1 root root 241, 2 Sep 14 12:51 /dev/intel-fpga-port.2
$ fpgabist /opt/intel/inteldevstack/hw/samples/nlb_mode_3/bin/nlb_mode_3.gbs -B 3b
Beginning FPGA Built-In Self-Test
Device: bus = 3b, device = 00, func = 0
//****** FME ******//
Object Id : 0xF200000
PCIe s:b:d:f : 0000:3B:00:0
Device Id : 0x09C4
Socket Id : 0x00
Ports Num : 01
Bitstream Id : 0x123456789ABCDEF
Bitstream Version : 1.2.3
Pr Interface Id : ce489693-98f0-5f33-946d-560708be108a
//****** PORT ******//
Object Id : 0xF100000
Device Id : 0x09C4
Socket Id : 0x00
Ports Num : 01
Accelerator Id : f7df405c-bd7a-cf72-22f1-44b0b93acd18
Accelerator GUID : f7df405c-bd7a-cf72-22f1-44b0b93acd18
//****** TEMP ******//
Device Id : 0x09C4
Socket Id : 0x00
Ports Num : 01
Package Temperature : 38 Centigrade
metrics_utils.c:633:enum_bmc_metrics_info() **ERROR** : Failed to load BMC SDR.
metrics.c:80:xfpga_fpgaGetNumMetrics() **ERROR** : Failed to Discover Metrics
Error getting number of metrics: not found
Error reading metrics from BMC: not found
//****** POWER ******//
Writing bitstream
Done
Running fpgadiag read test...
sysfs.c:1481:sync_object() **ERROR** : Error opening /sys/class/fpga/intel-fpga-dev.0/intel-fpga-fme.0/dperf/fabric/freeze: Permission denied
terminate called after throwing an instance of 'opae::fpga::types::exception'
what(): failed with return code FPGA_EXCEPTION at: sysobject.cpp:get():85
Failed Test: read
Command 'fpgadiag -B 0x3b --mode=read --read-vc=vh0 --write-vc=vh0 --multi-cl=4 --begin=1024, --end=1024 --timeout-sec=5 --cont' returned non-zero exit status 250
Running fpgadiag write test...
$ sudo fpgabist /opt/intel/inteldevstack/hw/samples/nlb_mode_3/bin/nlb_mode_3.gbs -B 3b
Done
Cachelines Read_Count Write_Count Cache_Rd_Hit Cache_Wr_Hit Cache_Rd_Miss Cache_Wr_Miss Eviction 'Clocks(@400 MHz)' Rd_Bandwidth Wr_Bandwidth
1024 540436620 0 0 0 0 0 0 2000964806 6.914 GB/s 0.000 GB/s
VH0_Rd_Count VH0_Wr_Count VH1_Rd_Count VH1_Wr_Count VL0_Rd_Count VL0_Wr_Count
540436620 1 0 0 0 0
1024 0 543165164 0 0 0 0 0 2000611414 0.000 GB/s 6.950 GB/s
0 543165165 0 0 0 0
Running fpgadiag trput test...
1024 487225740 488951172 0 0 0 0 0 2001626166 6.231 GB/s 6.253 GB/s
487225740 488951173 0 0 0 0
Finished Executing NLB (FPGA DIAG)Tests
Built-in Self-Test Completed.
$ aocl diagnose
aocl diagnose: Running diagnose from /opt/intel/inteldevstack/opencl/opencl_bsp/linux64/libexec
aocl diagnose: failed 3 times. First error below:
Vendor: Intel Corp
handle is: -2
Phys Dev Name Status Information
pac_a10_f100002Uninitialized Not configured with OpenCL BSP.
Found no active device installed on the host machine.
Please consult documentation for troubleshooting steps
DIAGNOSTIC_FAILED
BoonBengT_Altera
Hi @joeryan,
Thank you for posting in Intel community forum and hope all is well.
May I asked if you are trying to get started with the OPAE stack or running OpenCL on A10 PAC?
Which guide that you have followed to setup your environment?
Hope to hear from you soon.
Best Wishes
BB
joeryan
We were working on using the OPAE stack and were able to finally get an aocl diagnose output.  We have determined that FIM/BMC Firmware upgrades are needed to move to the latest OPAE/IntelDevStack.
As a related question, the archive page for version 1.1 (https://www.intel.com/content/www/us/en/software-kit/665876/intel-pac-with-intel-arria-10-gx-fpga-acceleration-stack-version-1-1.html?) links to FIM/BMC Firmware tools download with (https://www.bittware.com/fpga/intel/boards/pac-arria-10/).  However, this returns a 404 error from Bittware.  I am in the process of registering there, but is that the appropriate place to obtain the different firmware versions to upgrade through the versions to 1.2.1?
Joe
from https://www.intel.com/content/www/us/en/software-kit/665876/intel-pac-with-intel-arria-10-gx-fpga-acceleration-stack-version-1-1.html?
BMC Firmware and Tools Download:
Register at Intel® PAC Firmware and Tools and select Intel® PAC
BoonBengT_Altera
Hi @joeryan,
Apologies for the hold up, we have double checked this and supported from bittware with Intel PAC card has been concluded.
However customers can still engaged them to purchase a copy of Toolkit LITE, bittware will be more than happy to prepare a quote for that.
Hope that helps.
Best Wishes
BB
BoonBengT_Altera
Good day, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.
Best Wishes
BB
BoonBengT_Altera
Hi @joeryan,
Greetings, as we do not receive any further clarification on what is provided, we would assume challenge are overcome. Hence thread will no longer be monitored. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
