Programmable Devices
21611 Discussions
pin assignments
KenBee
Using Quartus 13.1 to program Cyclone IV.
Fitter reports - Trigger: missing drive strength and slew rate.
Pin Planner - Trigger (output pin) - Current strength 8mA, slew rate 2. (i,e, defaults)
I have tried changing the assignments and trying the fitter again but no better. Tried using a different PC, still no good. The program produces a .pof file and says the EPCS16 programmed OK, but the output is fixed high. I am presuming the above problem is the culprit.
Help would be gratefully received , but please keep it simple - I am not a programmer!
Ken
sstrell
Is "trigger" the name of an output signal?  You should probably show some code to understand what is happening here.
AqidAyman_Intel
Hi Ken,
Any updates on this issue? Do you still face it? If yes, can share your codes or any details that might help us to understand your issue?
Aqid
AqidAyman_Intel
Wish to follow up.
Do you still need help on this question?
Thanks for your response.
AqidAyman_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
