21592 Discussions
please small help
hi i need a please small help.
i have here a board whit a cyclone 2 and i wand a make a dump whit the quartus but i dont no how i must do it.
plase cane sambody help me.:eek:
have you compiled yuor source code first?
no, i wantd make a copy from oreginal.
how can i make a compilid from a orginal cuircuit???????
i have a dump of the 24c64
can you tell us which board exactly you have?
also tell us, which sample code did you compile?
the oreginal circuit is a satelite decoder.
-ep2c5t144c8n
-24c64
only i wand read the cyclone i have a dump of 24c64
and later wirte the soft in a blank board.
please help.
sure
do you know how to use QuartusII programmer?
launch the program from QuartusII tools menu.
and connect to your USB-Blaster to your board.
if you use Active Serial programming.
check Examine flag and start it.
you can read pof image from your FPGA(EEPROM)
if you use JTAG, tell me that it need another skill.
hi my friend:
i have a handmake jtag via ltp1 (bytblaster mv)
is thas ok???????
what do you intend to do with the JPG?>
A 24C64 (8 kByte) isn't able to store the configuration of EP2C5 (about 150 kByte), also it's not a supported configuration device. Your circuit most likely contains another programmable device, either memory or microcontroller with flash, that holds the configuration.
alsow a mpeg decoder fujitsu mb86h25b
There must be at least a program flash connected to the mb86h25b. It may also contain the Cyclone II configuration.
