21602 Discussions
problem on designing lfsr prng with implement the concept of bbs prng
Greeting, i am designing a lfsr prng, since my FYP supervisor has advise me to include some concept of bbs prng into it
i want to add on a security bits code output for each of my random number output
i had modified my coding but there are some problem i am facing and i dont know how to solve it, i had attached my output waveform
below is my modified VHDL coding:
library ieee;
use ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use work.lfsr_pkg.all;
entity lfsr1 is
port (
reset : in std_logic;
clk : in std_logic;
en : in std_logic;
count : out std_logic_vector (LFSR_W-1 downto 0); -- lfsr output
sc : out std_logic_vector (LFSR_W-1 downto 0)
end entity;
architecture rtl of lfsr1 is
signal count_i : std_logic_vector (LFSR_W-1 downto 0);
signal feedback : std_logic;
begin
-- option for LFSR size 11
feedback <= not(count_i(LFSR_W-1) xor count_i(LFSR_W-3));
sr_pr : process (clk)
variable sc1:std_logic_vector (LFSR_W-1 downto 0);
variable sc2:std_logic;
variable r:std_logic_vector(LFSR_W-1 downto 0);
begin
if (rising_edge(clk)) then
if (reset = '1') then
count_i <= (others=>'0');
elsif (en = '1') then
count_i <= count_i(LFSR_W-2 downto 0) & feedback;
for i in 0 to LFSR_W-1 loop
sc1:=count_i;
if sc1=1 then
sc2:='1';
else sc2:='0';
end if;
r(9):=r(10);
r(8):=r(9);
r(7):=r(8);
r(6):=r(7);
r(5):=r(6);
r(4):=r(5);
r(3):=r(4);
r(2):=r(3);
r(1):=r(2);
r(0):=r(1);
r(10):=sc2;
sc <= r;
end loop;
end if;
end if;
end process sr_pr;
count <= count_i;
end architecture;
testbench:
library ieee;
use ieee.numeric_std.ALL;
use std.textio.all;
entity tb_lfsr1 is
end entity;
architecture test of tb_lfsr1 is
constant PERIOD : time := 10 ns;
constant log_file: string := "res.log";
signal clk : std_logic := '0';
signal reset : std_logic := '1';
signal en : std_logic := '0';
signal count : std_logic_vector (LFSR_W-1 downto 0);
signal sc : std_logic_vector (LFSR_W-1 downto 0);
signal endSim : boolean := false;
component lfsr1 is
port (
clk : in std_logic;
en : in std_logic;
end component;
begin
clk <= not clk after PERIOD/2;
reset <= '0' after PERIOD*10;
-- Main simulation process
main_pr : process
begin
wait until (reset = '0');
wait until (clk = '1');
en <= '1';
for i in 0 to 7 loop
end loop;
en <= '0';
en <= '1';
while (not endSim) loop
end loop;
end process main_pr;
-- End the simulation
stop_pr : process
begin
if (endSim) then
assert false
report "End of simulation."
severity failure;
end if;
end process stop_pr;
DUT : lfsr1
port map (
clk => clk,
reset => reset,
en => en,
count => count,
sc => sc
-- Save data to file
save_data_pr : process
file file_id: text;
variable line_num: line;
variable cnt: integer := 0;
begin
-- Open the file
file_open(file_id, log_file, WRITE_MODE);
wait until (reset = '0' and en = '1');
-- Loop and write all values to a file
for cnt in 0 to 2048*2-1 loop
write(line_num, to_integer(unsigned(count)) );
writeline(file_id, line_num);
wait until (en = '1' and clk = '1');
end loop;
file_close(file_id);
endSim <= true;
end process save_data_pr;
end architecture;
i found that my security bits code just generated single output and then the rest were 0
please anyone can help me to look into the problem and teach me how to modify?
appreciate for your helping
the VHDL coding i was take from - http://fpgasite.blogspot.co.id/2017/04/pseudo-random-generator-tutorial.html
i am doing the modification based on their coding
https://alteraforum.com/forum/attachment.php?attachmentid=15297&stc=1
