21602 Discussions
problem with VHDL
I have been involved in some programming project but suddenly a problem started coming.
in the timing.vhd file from line 114 to 147 i have defined two signals sSTOP and sStop_1 as well as sTEMP. when I simulate these files with timing as a top level entity, the vector waveform file always show a negative sSTOP signal, not only this the initial value of sTEMP is "001" but it takes some random value.
is there a bug in the software?
if not when i try to burn the same project on cyclone III it never shows me the output
kindly help me in this and please rectify if there are some mistakes .
thanq
Your zip file seems to be corrupted. Just embed your code in your message between code tags.
sorry there was some error now i have uploaded again
plz try this one
begin
ACC1 :acc port map (
inp => sCHANNEL(to_integer(sTEMP)),
rst => sRST,
clk => sCLK,
imp => sComp,
op => sOP
counter1 : counter port map (
rst => sRST,
trigger => sTRIG_in,
clk => sCLK,
digit => sDIGIT
compare1 : compare port map (
clk => sCLK,
rst => sRST,
inp1 => sOP,
inp2 => sDIGIT,
output => sComp
proc1 : proc port map (
inp_pulse => sComp,
clk => sCLK,
rst => sRST,
op => sOutput
sSIGNAL <= (others => '0');
process(rst,clk)
begin
if (rst = '1') then
sTEMP <= "001";
sStop_1 <= '1';
-- sOP <= (others => '1');
elsif (clk'event and clk = '1' and sCOMP = '1') then
sTEMP <= sTEMP + "001";
if (sTEMP = "100") then
sStop_1 <= '0';
end if;
end if;
end process;
Process (rst, clk)
begin
if (rst = '1') then
sSTOP <= '1';
elsif (clk' event and clk = '1') then
if (sCHANNEL(to_integer(sTEMP))=X"00000") then
sSTOP <= '0';
end if;
end if;
end process;
--sample1 <= sStop_1;
--sample <= sSTOP;
sRST <= rst;
sCLK <= clk;
sTrig_in <= trig_in;
sCHANNEL <= CHANNEL;
output <= sSTOP and sOutput and sStop_1;
end behavior;
looking at your code, once sStop goes to '0', it stays there until async reset is asserted. Did you mean it to work like this?
