21611 Discussions
problem with aocl install
I tried to compile main.cpp from an example provided by Altera (vector_add), and the compilation failed. it seems the compilation failed because ths FCDs wasn't installed.
but when i try to install the drivers (with aocl install) i get the following message :
"error: cannot open service control manager
make sure you are running with Administrator privileges"
how can i issue this problem ?
thanks for your help
