21615 Discussions
problems on my thesis
Heyy I'm doing my thesis on tetris game simulation on fpga and not good at vhdl that much. Your asist would be great. At first, i need to make the code below work. It's just the beginning of VGA code.
I'm using DE0 board (the reason of may problems I think), Quartus II and vhdl.
I had to change VGA_CLK, VGA_BLANK, VGA_SYNC as a comment cause they dont exist in DE0's pin assignment list.
the problems are these.
warning (10631): vhdl process statement warning at vga.vhd(102): inferring latch(es) for signal or variable "vga_hblank", which holds its previous value in one or more paths through the process
warning: output pins are stuck at vcc or gnd
warning (13410): pin "vga_hs" is stuck at gnd
warning (13410): pin "vga_vs" is stuck at gnd
warning (13410): pin "vga_r[0]" is stuck at gnd
warning (13410): pin "vga_r[1]" is stuck at gnd
warning (13410): pin "vga_r[2]" is stuck at gnd
warning (13410): pin "vga_r[3]" is stuck at gnd
warning (13410): pin "vga_g[0]" is stuck at gnd
warning (13410): pin "vga_g[1]" is stuck at gnd
warning (13410): pin "vga_g[2]" is stuck at gnd
warning (13410): pin "vga_g[3]" is stuck at gnd
warning (13410): pin "vga_b[0]" is stuck at gnd
warning (13410): pin "vga_b[1]" is stuck at gnd
warning (13410): pin "vga_b[2]" is stuck at gnd
warning (13410): pin "vga_b[3]" is stuck at gnd
warning: design contains 2 input pin(s) that do not drive logic
warning (15610): no output dependent on input pin "reset"
warning (15610): no output dependent on input pin "clk_default"
pin assignment
ok vga_b[3] location pin_k18 yes
ok vga_b[1] location pin_k21 yes
ok vga_b[2] location pin_j22 yes
ok vga_b[0] location pin_k22 yes
ok vga_g[3] location pin_j21 yes
ok vga_g[2] location pin_k17 yes
ok vga_g[1] location pin_j17 yes
ok vga_g[0] location pin_h22 yes
ok vga_hs location pin_l21 yes
ok vga_r[3] location pin_h21 yes
ok vga_r[2] location pin_h20 yes
ok vga_r[1] location pin_h17 yes
ok vga_r[0] location pin_h19 yes
ok vga_vs location pin_l22 yes
ok reset location pin_j6 yes
ok clk_default location pin_g21 yes
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity vga is port ( reset : in std_logic; clk_default : in std_logic; --default is 50 MHz -- VGA_CLK, --Dot clock to DAC -- VGA_BLANK, --Active-Low DAC blanking control -- VGA_SYNC, --Active-Low DAC Sync on Green VGA_HS, --Active-Low Horizontal Sync VGA_VS : out std_logic; --Active-Low Vertical Sync VGA_R, VGA_G, VGA_B : out std_logic_vector(3 downto 0) ); end vga; architecture rtl of vga is --Video parameters constant HTOTAL : integer := 800; constant HSYNC : integer := 96; constant HBACK_PORCH : integer := 48; constant HACTIVE : integer := 640; constant HFRONT_PORCH : integer := 16; constant VTOTAL : integer := 525; constant VSYNC : integer := 2; constant VBACK_PORCH : integer := 33; constant VACTIVE : integer := 480; constant VFRONT_PORCH : integer := 10; constant RECTANGLE_HSTART : integer := 100; constant RECTANGLE_HEND : integer := 540; constant RECTANGLE_VSTART : integer := 100; constant RECTANGLE_VEND : integer := 380; --Horizontal position (0-800) signal Hcount : std_logic_vector(3 downto 0); --Vertical position (0-524) signal Vcount : std_logic_vector(3 downto 0); signal EndOfLine, EndOfField : std_logic; signal vga_hblank, vga_hsync,vga_vblank, vga_vsync : std_logic; --Sync. signals signal rectangle_h, rectangle_v, rectangle : std_logic; --rectangle area signal clk : std_logic; --Should be 25.125 MHz begin CDivider : process (clk_default) begin if clk_default'event and clk_default = '1' then if (clk = '0') then clk <= '1'; else clk <= '0'; end if; end if; end process CDivider; HCounter : process (clk, reset) begin if reset = '1' then Hcount <= (others => '0'); elsif clk'event and clk = '1' then if EndOfLine = '1' then Hcount <= (others => '0'); else Hcount <= Hcount + 1; end if; end if; end process HCounter; EndOfLine <= '1' when Hcount = HTOTAL - 1 else '0'; VCounter: process (clk, reset) begin if reset = '1' then Vcount <= (others => '0'); elsif clk'event and clk = '1' then if EndOfLine = '1' then if EndOfField = '1' then Vcount <= (others => '0'); else Vcount <= Vcount + 1; end if; end if; end if; end process VCounter; EndOfField <= '1' when Vcount = VTOTAL - 1 else '0'; HSyncGen : process (clk, reset) begin if reset = '1' then vga_hsync <= '1'; elsif clk'event and clk = '1' then if EndOfLine = '1' then vga_hsync <= '1'; elsif Hcount = HSYNC - 1 then vga_hsync <= '0'; end if; end if; end process HSyncGen; HBlankGen : process (clk, reset) begin if reset = '1' then vga_hblank <= '1'; elsif clk'event and clk = '1' then if Hcount = HSYNC + HBACK_PORCH then vga_hblank <= '0'; elsif Hcount = HSYNC + HBACK_PORCH + HACTIVE then vga_hblank <= '1'; end if; end if; end process HBlankGen; VSyncGen : process (clk, reset) begin if reset = '1' then vga_vsync <= '1'; elsif clk'event and clk = '1' then if EndOfLine ='1' then if EndOfField = '1' then vga_vsync <= '1'; elsif Vcount = VSYNC - 1 then vga_vsync <= '0'; end if; end if; end if; end process VSyncGen; VBlankGen : process (clk, reset) begin if reset = '1' then vga_vblank <= '1'; elsif clk'event and clk = '1' then if EndOfLine = '1' then if Vcount = VSYNC + VBACK_PORCH - 1 then vga_vblank <= '0'; elsif Vcount = VSYNC + VBACK_PORCH + VACTIVE - 1 then vga_vblank <= '1'; end if; end if; end if; end process VBlankGen; RectangleHGen : process (clk, reset) begin if reset = '1' then rectangle_h <= '1'; elsif clk'event and clk = '1' then if Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HSTART then rectangle_h <= '1'; elsif Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HEND then rectangle_h <= '0'; end if; end if; end process RectangleHGen; RectangleVGen : process (clk, reset) begin if reset = '1' then rectangle_v <= '0'; elsif clk'event and clk = '1' then if EndOfLine = '1' then if Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VSTART then rectangle_v <= '1'; elsif Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VEND then rectangle_v <= '0'; end if; end if; end if; end process RectangleVGen; rectangle <= rectangle_h and rectangle_v; VideoOut: process (clk, reset) begin if reset = '1' then VGA_R <= "0000"; VGA_G <= "0000"; VGA_B <= "0000"; elsif clk'event and clk = '1' then if rectangle = '1' then VGA_R <= "1111"; VGA_G <= "1111"; VGA_B <= "1111"; elsif vga_hblank = '0' and vga_vblank ='0' then VGA_R <= "0000"; VGA_G <= "0000"; VGA_B <= "1111"; else VGA_R <= "0000"; VGA_G <= "0000"; VGA_B <= "0000"; end if; end if; end process VideoOut; -- VGA_CLK <= clk; VGA_HS <= not vga_hsync; VGA_VS <= not vga_vsync; -- VGA_SYNC <= '0'; -- VGA_BLANK <= not (vga_hsync or vga_vsync); end rtl;
Did you connect your signals correctly?
For example:
"clk_default" to CLOCK_50
"reset" to the inverse of the BUTTON signals
Hope this works...
I think the main problem is that you are dividing your clock by two to generate a logic clock. This is generally a bad thing to do. You should clock everything from the main clock and then produce clock enables when everything needs to change.
As Tricky mentions, making your own clock (divider) is not good design practice. That aside, this is not the major problem in your design.
You have used signals that are not connected to pins of your DE0 board.
I added external pins BUTTON and CLOCK_50 instead of your reset and clk_default.
Also the vectors Hcount and Vcount were too small: 4 bit vectors to represent horizontal position from 0-800 as well as vertical position 0-524.
With the adapted code below it runs on my DE0.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity vga is port ( -- reset : in std_logic; -- clk_default : in std_logic; --default is 50 MHz BUTTON : in std_logic_vector (2 downto 0); -- Sanmao CLOCK_50 : in std_logic; -- Sanmao -- VGA_CLK, --Dot clock to DAC -- VGA_BLANK, --Active-Low DAC blanking control -- VGA_SYNC, --Active-Low DAC Sync on Green VGA_HS, --Active-Low Horizontal Sync VGA_VS : out std_logic; --Active-Low Vertical Sync VGA_R, VGA_G, VGA_B : out std_logic_vector(3 downto 0) ); end vga; architecture rtl of vga is --Video parameters constant HTOTAL : integer := 800; constant HSYNC : integer := 96; constant HBACK_PORCH : integer := 48; constant HACTIVE : integer := 640; constant HFRONT_PORCH : integer := 16; constant VTOTAL : integer := 525; constant VSYNC : integer := 2; constant VBACK_PORCH : integer := 33; constant VACTIVE : integer := 480; constant VFRONT_PORCH : integer := 10; constant RECTANGLE_HSTART : integer := 100; constant RECTANGLE_HEND : integer := 540; constant RECTANGLE_VSTART : integer := 100; constant RECTANGLE_VEND : integer := 380; --Horizontal position (0-800) signal Hcount : std_logic_vector(9 downto 0); -- Sanmao --Vertical position (0-524) signal Vcount : std_logic_vector(9 downto 0); -- Sanmao signal EndOfLine, EndOfField : std_logic; signal vga_hblank, vga_hsync,vga_vblank, vga_vsync : std_logic; --Sync. signals signal rectangle_h, rectangle_v, rectangle : std_logic; --rectangle area signal clk : std_logic; --Should be 25.125 MHz signal clk_default : std_logic; signal reset : std_logic; begin CDivider : process (clk_default) begin if clk_default'event and clk_default = '1' then if (clk = '0') then clk <= '1'; else clk <= '0'; end if; end if; end process CDivider; HCounter : process (clk, reset) begin if reset = '1' then Hcount <= (others => '0'); elsif clk'event and clk = '1' then if EndOfLine = '1' then Hcount <= (others => '0'); else Hcount <= Hcount + 1; end if; end if; end process HCounter; EndOfLine <= '1' when Hcount = HTOTAL - 1 else '0'; VCounter: process (clk, reset) begin if reset = '1' then Vcount <= (others => '0'); elsif clk'event and clk = '1' then if EndOfLine = '1' then if EndOfField = '1' then Vcount <= (others => '0'); else Vcount <= Vcount + 1; end if; end if; end if; end process VCounter; EndOfField <= '1' when Vcount = VTOTAL - 1 else '0'; HSyncGen : process (clk, reset) begin if reset = '1' then vga_hsync <= '1'; elsif clk'event and clk = '1' then if EndOfLine = '1' then vga_hsync <= '1'; elsif Hcount = HSYNC - 1 then vga_hsync <= '0'; end if; end if; end process HSyncGen; HBlankGen : process (clk, reset) begin if reset = '1' then vga_hblank <= '1'; elsif clk'event and clk = '1' then if Hcount = HSYNC + HBACK_PORCH then vga_hblank <= '0'; elsif Hcount = HSYNC + HBACK_PORCH + HACTIVE then vga_hblank <= '1'; end if; end if; end process HBlankGen; VSyncGen : process (clk, reset) begin if reset = '1' then vga_vsync <= '1'; elsif clk'event and clk = '1' then if EndOfLine ='1' then if EndOfField = '1' then vga_vsync <= '1'; elsif Vcount = VSYNC - 1 then vga_vsync <= '0'; end if; end if; end if; end process VSyncGen; VBlankGen : process (clk, reset) begin if reset = '1' then vga_vblank <= '1'; elsif clk'event and clk = '1' then if EndOfLine = '1' then if Vcount = VSYNC + VBACK_PORCH - 1 then vga_vblank <= '0'; elsif Vcount = VSYNC + VBACK_PORCH + VACTIVE - 1 then vga_vblank <= '1'; end if; end if; end if; end process VBlankGen; RectangleHGen : process (clk, reset) begin if reset = '1' then rectangle_h <= '1'; elsif clk'event and clk = '1' then if Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HSTART then rectangle_h <= '1'; elsif Hcount = HSYNC + HBACK_PORCH + RECTANGLE_HEND then rectangle_h <= '0'; end if; end if; end process RectangleHGen; RectangleVGen : process (clk, reset) begin if reset = '1' then rectangle_v <= '0'; elsif clk'event and clk = '1' then if EndOfLine = '1' then if Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VSTART then rectangle_v <= '1'; elsif Vcount = VSYNC + VBACK_PORCH - 1 + RECTANGLE_VEND then rectangle_v <= '0'; end if; end if; end if; end process RectangleVGen; rectangle <= rectangle_h and rectangle_v; VideoOut: process (clk, reset) begin if reset = '1' then VGA_R <= "0000"; VGA_G <= "0000"; VGA_B <= "0000"; elsif clk'event and clk = '1' then if rectangle = '1' then VGA_R <= "1111"; VGA_G <= "1111"; VGA_B <= "1111"; elsif vga_hblank = '0' and vga_vblank ='0' then VGA_R <= "0000"; VGA_G <= "0000"; VGA_B <= "1111"; else VGA_R <= "0000"; VGA_G <= "0000"; VGA_B <= "0000"; end if; end if; end process VideoOut; -- VGA_CLK <= clk; VGA_HS <= not vga_hsync; VGA_VS <= not vga_vsync; clk_default <= CLOCK_50; -- Sanmao reset <= not BUTTON(0); -- Sanmao -- VGA_SYNC <= '0'; -- VGA_BLANK <= not (vga_hsync or vga_vsync); end rtl;
Good luck with Tetris!
thanks guys it works!!
