Programmable Devices
21615 Discussions
quartus download
HI to everyone,
I am really in trouble about Quartus downloading and installation procedure and result.
After a series of tentatives I downloaded Quartus subscription 30days to check a design with Startix IV and V.
After a very long time to download the program (using the altera download program) the program seems installed.
I am using a windowsXP 32bit SP2 (just appointed for quartus), when I started an error is issued saying "application was not correctly initialized (0xc0150002).
what I have to do?
thank you in advance
maurizio stefani
Hi
Are you sure Quartus is installed ? Maybe you have only decompressed files.
Downloader downlaods Quartus_install
Quartus_install first decompress files to temporary directory : approx 6 Go !!
then it installs to directory you specified : it copies the 6Go to the destination directory and do some register settings
Have you got enough memory ? See release note : for Stratix you need many many many RAM.
You should send an Altera request : see menu>support>.... in www.altera.com
HI, thank you mmTsuchi,
I used the install file supplied by altera,
again, I am not in the phase to compile, I would like just to start quartus.
I have sent an enquire to altera also without any answer
thank you and I hope some one can help me
maurizio stefani
32bit winXP is not suitable for stratix 4 and 5, as you can only get a max of 3GB of ram (and that is with some OS tweeks, otherwise max is 2GB). So you're on to a ***** before you start as you can only compile the smallest S4 device. Minimum recommended ram for the smallest Stratix V device is 8GB
