21615 Discussions
quartus_sh --simlib_comp is adding -dbg compile option
cdesmouliers
Is there a way to compile the libraries without the "-dbg" option added to the scripts ?
Christophe
RichardTanSY_Altera
You may checkout this page on the correct way in Using EDA Simulation Library Compiler in the Command Line:
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm?elq_cid=7897019_ts1673839339971&erpm_id=11951528_ts1673839339971#mapIdTopics/mwh1391807004003.htm
There is no -dbg option required in the cmd line so you can exclude it.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
cdesmouliers
I know there is no -dbg option to the command line.
What I am saying is that the resulting compiled libraries are compiled with the -dbg option for Riviera Pro.
I am asking if there is a way to tell to quartus_sh not to compile those with -dbg. Also is there a reason why it was done this way.
Christophe
RichardTanSY_Altera
May I understand is there an issue with the -dbg compile option?
As of now, I don't think there is an option to turn off the -dbg option as the command script was wrote by the engineering team years ago.
Richard Tan
cdesmouliers
We noticed that when we started doing coverage.
Coverage data are picked up for all intel components which is not what we want.
Also, the -dbg compile option prevents from some optimizations.
Aldec provides precompiled library without the -dbg option but I wanted to know if there is a way to recompile on our side without this.
Christophe
RichardTanSY_Altera
Let me check this with the engineering team. See if there is a way to exclude the -dbg option.
Richard Tan
RichardTanSY_Altera
I yet to receive response from the engineering team. I will follow up with them.
RichardTanSY_Altera
As of now, we do not have the flexibility to exclude -dbg from the script.
You will need to get the precompiled library without the -dbg option from the Aldec.
Richard Tan
RichardTanSY_Altera
As there is solution to this issue, I now transition this thread to community support.
Richard Tan
cdesmouliers
Hello Richard,
Thanks for looking into it.
Is there a way to generate only the compilation scripts for the Intel libraries ?
Christophe
