Programmable Devices
20920 Discussions
question about arithmetic operator '+'
Every time I try following code, there is a error saying that "Error (10327): VHDL error at Arithmetic.vhd(35): can't determine definition of operator ""+"" -- found 0 possible definitions", Can anyone shed some light? Thanks.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.all;
entity Arithmetic is
port(
var3 : in bit_vector(7 downto 0);
var9 : out bit_vector(8 downto 0)
end Arithmetic;
architecture architecture of Arithmetic is
signal var8 : bit_vector(8 downto 0);
begin
var8 <= '0' & var3;
var9 <= var8 + var8;
end architecture;
You get the error, because you are using unsuitable data types and incompatible libraries.
There are two possible ways:
- You can refer to the legacy non-IEEE STD_LOGIC_UNSIGNED library. But then you have to import STD_LOGIC_ARITH instead of NUMERIC_STD. bit_vector has to be changed to std_logic_vector in addition
- You can use correct VHDL types and the official IEEE.NUMERIC_STD library. The involved signals should be defined as unsigned in this case.
As a side remark, the inplemented left-shift can be simply written as
var9 <= var3 & '0';
without involving numeric types.
