Every time I try following code, there is a error saying that "Error (10327): VHDL error at Arithmetic.vhd(35): can't determine definition of operator ""+"" -- found 0 possible definitions", Can anyone shed some light? Thanks.
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use ieee.numeric_std.all; entity Arithmetic is port( var3 : in bit_vector(7 downto 0); var9 : out bit_vector(8 downto 0) ); end Arithmetic; architecture architecture of Arithmetic is signal var8 : bit_vector(8 downto 0); begin var8 <= '0' & var3; var9 <= var8 + var8; end architecture;Link Copied
You get the error, because you are using unsuitable data types and incompatible libraries.
There are two possible ways: - You can refer to the legacy non-IEEE STD_LOGIC_UNSIGNED library. But then you have to import STD_LOGIC_ARITH instead of NUMERIC_STD. bit_vector has to be changed to std_logic_vector in addition - You can use correct VHDL types and the official IEEE.NUMERIC_STD library. The involved signals should be defined as unsigned in this case. As a side remark, the inplemented left-shift can be simply written asvar9 <= var3 & '0';
without involving numeric types.
![](/skins/images/54BF544B471F3F61DFD338F1D58F9426/responsive_peak/images/icon_anonymous_message.png)
