21611 Discussions
rdreq didnt read all the data in dcFIFO (functional simulation)
hi,
i have question regarding to rdreq in DCFIFO. i'm writing 4 16-bits data into dcFIFO at 100Mhz speed. and read at 200Mhz speed. the problem now is, rdreq didnt read all 4 data in FIFO. only 3 available(data2,data3 and data4 only). data 1 is missing. i run for functional simulation only.
could someone help me on this? i'm stuck almost 1 day already.
DCFIFO setting and simulation output attached.
-Farhan
can someone help me? :(
Note that at beginning wrfull pin is high, so, first write attempt is ignored.
wrfull looks high on that first write. There is circuitry on by default that disables extra writes/reads when full or empty, as that can completely corrupt the fifo.
ok.noted.
now, i have another issue when combining my sub blocks (datapath + CU).
when i simulated the datapath block separately, data is read out nicely in 4 clock cycles at every rising edge during rdreq is HIGH. but, now, when i tested in combined block with CU, it's failed. FYI, rdreq(read_fifo) is not controlled by CU. i control it manually. this CU is responsible for write operation(which is successful simulated). rdreq depends on "Routerclk" and writereq(write_fifo) depends on "clk".
i attached the simulation for combined design + FBD + successful simulation for Non combined design.
As u can see in the encapunitsimulation picture, the data is written to FIFO(during write_fifo is HIGH). FOUR 16-bit data is written to FIFO(i put the number in pink color). but, when rdreq is HIGH(read_fifo is HIGH), it's missed the last data, which is 0000000000000000. encapunitsimulation2 shows weird counting of the data in fifo.
i want the data to be read out as in simulationnoncombined picture.
(functional test simulation).
Please help.
Thanks Guru..
can someone help me on this?
Thanks a lot!
