21602 Discussions
rx_clkout - route to which output pin
I'm planning to use the ALT_GX module in an Arria II GX FPGA like indicated here:
http://www.altera.com/literature/an/an610.pdf
Page 7, figure 4.
The question I have is which output pin should I route the rx_clkout to to feed the clean up PLL? Can it be any I/O pin, or should it be a pll#_clkout pin?
Thank you
Allow Quartus to be your guide; P&R a design using a regular I/O and then again using a PLL_OUT pin.
I suspect that you will get a warning regarding excess jitter when you use a regular I/O pin. That is the type of warning you get when driving a PLL clock output to a non PLL-out pin.
Cheers,
Dave
I'll will examine what Quartus does, but it seems curious that the PLL_OUT pin can only be pseudo-differential, but if I use a regular out pin, I can drive the pins in true differential, like LVDS. Either way, if I am using this signal to feed a clock jitter cleaner chip, it seems like I will suffer (either because I am not using a clock chip, or because I'm not driving in true differential style).
Therefore, which is the better way to go?
Seeing that
Page 7, figure 4.
Suggests to do this, what is the suggested pin type to use?
Thank you
--- Quote Start ---
--- Quote End ---
I would recommend the PLL_OUT pin, along with whatever resistors are needed to make the pseudo-differential signal compatible with the TI clock chip. Since the signal is a clock, you can AC-couple, so you'll just need to check that the amplitude of the output does not exceed the input to the TI jitter cleaner.
File a Service Request with TI and ask which pins they used, or recommend. Please post their response here, in case others have this same question.
Cheers,
Dave
