21615 Discussions
scfifo-what is the problem
from this vhdl code,i make this as an avalon slave component on the cyclon2 device, and i get the output (sender) as peaks (nearly impulse) , what may be the problem?
is it something related to lpm_showahead or use_eab values,or rdrequest and wrrequest timing?
library altera;
use altera.altera_europa_support_lib.all;
library altera_mf;
use altera_mf.all;
library lpm;
use lpm.all;
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity tele is
port (
-- inputs:
signal address : in std_logic_vector (1 downto 0);
signal chipselect : in std_logic;
signal clk : in std_logic;
signal reset_n : in std_logic;
signal write_n : in std_logic;
signal writedata : in std_logic_vector (7 downto 0);
-- outputs:
--signal the_output : out std_logic;
signal tx_empty : out std_logic;
signal tx_full : out std_logic;
signal tx_used : out std_logic_vector (5 downto 0);
signal sender : out std_logic_vector (7 downto 0)
end entity tele;
architecture europa of tele is
component scfifo is
generic (
lpm_numwords : integer;
lpm_showahead : string;
lpm_width : integer;
lpm_widthu : integer;
overflow_checking : string;
underflow_checking : string;
use_eab : string
port (
signal full : out std_logic;
signal usedw : out std_logic_vector (5 downto 0);
signal q : out std_logic_vector (7 downto 0);
signal empty : out std_logic;
signal rdreq : in std_logic;
signal data : in std_logic_vector (7 downto 0);
signal sclr : in std_logic;
signal clock : in std_logic;
signal wrreq : in std_logic
end component scfifo;
signal wrrequest : std_logic;
signal rdrequest : std_logic;
signal sclr_me : std_logic;
begin
write_fifo : scfifo
generic map(
lpm_numwords => 64,
lpm_showahead => "off",
lpm_width => 8,
lpm_widthu => 6,
overflow_checking => "on",
underflow_checking => "on",
use_eab => "off"
port map(
clock => clk,
data => writedata,
empty => tx_empty,
full => tx_full,
q => sender,
rdreq => rdrequest,
sclr => sclr_me,
usedw => tx_used,
wrreq => wrrequest
rdrequest <='1';
sclr_me <= '0';
wrrequest <= '1';
end europa;
There is no functional purpose in using a fifo if you write and read data together at the same rate.
yes,kaz that is right but here i m trying to see that the output of the fifo is electrically and logically right,i tried meaningful fifo usage also like :
process(clk,reset_n)
begin
if reset_n=0 then
sender <="00000000";
elsif clk'event and clk='1' and full = '1' then
sender_out <= sender;
end if;
something like that but the result was same that i see the output pins' voltages very strange like impulses.
for example i write 0xa5 continuosuly,i look @ the pins of the output sender from oscilloscope and see the 1 bits and 0 bits @ right pins but 1 bits are electrically strange,that is they are not a step like function but like periodic impulses
is it something about the concurrency problem of the rdrequest and wrrequest signals?
Your last code still doesn't tell me about state of fifo rd/wr itself.
However, you should avoid reading empty fifo at start or full fifo.
you better use SignalTap to make your study instead of scope.
go to files > new > stp(signaltap) > enter your clk in the clk entry and enter your nodes, recompile and see. it needs usb blaster connected.
I don't foresee any problems with altera scfifo. You better wait for few bytes then start reading.
thanx for attention kaz,yes,thats right that reading empty or full fifo is wrong,so i make the rdrequest high when usedw signal (how many words exist in buffer) is for example 8 or 9 for a 64 byte buffer,and in vwf file the simulation is ok but when i instantiate this vhdl code in sopc and create the system, i get those periodic impulses on oscilloscope instead of the 1 bits.
i will also try to see the results in signaltap as you suggest.
