21611 Discussions
schematics LED connection
what is difference when we connect resister b/w fpga and led,
And Fpga is directly connected with led then pull down?
shahul
use resister can reduce the current and the brightness of the led.
i have attached the two different type of interface with led.
can any one differentiate it?
shahul
please reply to the above question?
I don't understand your question... putting the resistors before or after the leds doesn't change anything, as in both cases they are in series with the leds.
But with 10k I don't think that you'll see a lot. Just check the LED datasheet for the recommended current and standard forward voltage, and determine the nominal value for your resistors.
Hi Daixiwen,
why i ask this question is in our FPGA we have 8 leds connected as the top schematics shown in that figure.At the time of power ON all led glow. I don't no why this leds are glowing.it should be in off state.
shahul
Before configuration all the pins have a weak pull-up, so this can explain why you see them glowing. It should be a lot dimmer than with an output pin at logical '1' though.
Mostly, people are operating LEDs with active low FPGA outputs and anode connected to 3.3V for the said reason.
