21615 Discussions
sdo file not generated in altera
we wer doing Post synthesis simulation.
For that we use Altera Quartus Prime Standard Edition 15.1 in linux,we have qpf file with which we tried to generated .vho and .sdo file by the following link
http://cseweb.ucsd.edu/classes/fa10/cse140l/lab2/lab2_tutorial_timinig_simulation.pdf (http://cseweb.ucsd.edu/classes/fa10/cse140l/lab2/lab2_tutorial_timinig_simulation.pdf
we were only able to generate .vho file,for the cyclone v device,please help me with any changes to be made to generate .sdo or .sdf file.
The EDA netlist writer does not currently support gate-level simulation for the V-Series Hard IP for PCI Express® MegaCore® Function.
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd12102013_720.html
Kindly refer previous threads also.
https://alteraforum.com/forum/showthread.php?t=36762
https://alteraforum.com/forum/showthread.php?t=50750
Let me know if this has helped or if you need any further assistance.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Sir,
Thank you very much for the clarity. I have seen the Below things.Let me clear another question Is Timing Quest timing Analysis Possible. If Yes, could you share some procedures to follow the process of Timing Quest timing analysis in same Quartus Prime standard Edition 15.1 version and for the same Cyclone v family devices.
--- Quote Start ---
The EDA netlist writer does not currently support gate-level simulation for the V-Series Hard IP for PCI Express® MegaCore® Function.https://www.altera.com/support/support-resources/knowledge-base/solutions/rd12102013_720.html
Kindly refer previous threads also.https://alteraforum.com/forum/showthread.php?t=36762
Anand Raj Shankar
--- Quote End ---
Thanks and Regards
Shyam K
