21611 Discussions
set_clock_group constraints question!! plz help..
JJin01
I have clocks, one of which is a ripple clock. I don't know how to set_clock_group this.
Details are shown in the picture.
If you look at the picture, there are a_clock and b,c,d,e. a_clock is the clock that comes into a input port, and b is the half-rate ripple clock made from a_clock. And c_clock is also input clock, a_clock and c_clock are completely asynchronous clock.
I muxed the a and b clock and specified d and e_clock respectively using create_generate_clock.
i'm about to set_clock_group them all. As far as I know, d and e have to use -exclusive, but the problem is that a,b,d,e are all related clocks, which are confusing.
Tell me how to modify the set_clock_group in the picture.
Thank you so much.
Abe
Valued Contributor II
You could use something like this:
set_time_format -unit ns -decimal_places 3 # Create the first input clock to the mux create_clock -period 10 -name clockA [get_ports a_clock] # Create the second input clock to the mux create_clock -period 10 -name clockB [get_ports b_clock] #Cut transfers between FirstClock and SecondClock set_clock_groups -exclusive -group {clockA} -group {clockB}
or the following for externally switched clocks
set_time_format -unit ns -decimal_places 3 # Create the first input clock on the clock port create_clock -period 10 -name clockA [get_ports a_clock] # Create the second input clock on the same clock port create_clock -period 10 -name clockB [get_ports b_clock] -add # Cut transfers between FirstClock and SecondClock set_clock_groups -exclusive -group { clockA } -group { clockB }
KhaiChein_Y_Intel
You can use set_clock_groups with either [-asynchronous] or [-exclusive]. Asynchronous clocks (-asynchronous) are completely unrelated: they have different ideal clock sources. Exclusive clocks (-exclusive) are not active at the same time, such as multiplexed clocks.
