21610 Discussions
short between Gnd and +5 volt in DE0
Hi ..
i have altera DE0 Kit
when i was working on the project i shorted between the gnd and +5v on the pin expansion out
and the kit want work after this short !! :\
is the kit damaged !! :\
http://www.alteraforum.com/forum/attachment.php?attachmentid=10554&stc=1
I think it probably is damaged, yes. I'm afraid that is a difficult lesson learned the hard way. Look after your hardware!
Alex
Remove all custom connections.
Check if 5v voltage regulator is gone and replace it if doesn't works.
--- Quote Start ---
--- Quote End ---
which on of those ?
and can i test it on the board ?
http://www.alteraforum.com/forum/attachment.php?attachmentid=10566&stc=1
thx bro but it work fine with the adapter
