21591 Discussions
signal power estimation
Hello guys..
I'm trying to implement a block that evaluates the signal rms value along n samples.
So, using the std definition one must do (x_k is a complex number so I have to take in account |x_k|):
http://upload.wikimedia.org/math/0/1/4/014a453df92ed77eca97b228f0624d9f.png
The simplier way I have in mind is to use an accumulator. By the way it will indroduce some overflow issues. There is a good way in doing this ??
Thank you !
--- Quote Start ---
Hello guys..
Thank you !
--- Quote End ---
since your input is complex then square Re(Re*Re) + square Im(Im*Im) then accumulate this result over say 2^20 samples.
The accumulator will need 20 bits extra(over that of adder result) to avoid overflow. For 1/n Discard 20 LSBs when you read final result before clearing it to restart.
for square root, avoid it if you don't need it else use LUT or ip
--- Quote Start ---
--- Quote End ---
Dear Kaz,
Please correct me if I'm wrong.. I think that in the worst case, at each addition I should need an extra bit. In that case if I add 2^20 samples I will need 2^20 extra bits... Or not ??
Probably I've only to try and find the correct value of bit needed to take 2^20 samples without overflow..
--- Quote Start ---
Dear Kaz,
--- Quote End ---
No that sort of bits is enough to count all cosmic stars or even my cash.
for each pair of adds you need one bit so for 2^20 samples addition you need 20 bits more.(power of 2 maths)
imagine your input is just 1 (one bit), you add up 2^20 samples of 1, what you get?
1*2^20 = 2^20 which needs 20 bits(+1 bit)
--- Quote Start ---
--- Quote End ---
Dear kaz
It's ok. But what about working with 16 bits words ?
If you add up 2^20 samples of 4 you will get 4*2^20 that needs more than 21 bits.. or not ?
My problem is not the overflow of the counter but the one of the sum.
--- Quote Start ---
Dear kaz
--- Quote End ---
4*2^20 requires 3 bits + 20 bits = 23 bits.
in your case you have to multiply say 8 bits * 8bits => 16 bits +16bits => 17 bits + 20bits => 37 bits
You can imagine that by cascading pairs of additions:
sample1(17bits) + sample2(17 bits) needs 18 bits (res1)
sample3(17bits) + sample4(17 bits) needs 18 bits (res2)
res1(18bits) + res2(18 bits) needs 19 bits
thus you imagine 20 cascaded stages of addition needed for 2^20 samples
Dear Kaz
I've got the point. That seems a nice solution !
But if i want to implement the adder in a cascaded stages style I have to do it by hand.. I was thinking about something recursive:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8569
--- Quote Start ---
Dear Kaz
--- Quote End ---
using parallel adders wastes massive number of adders (2^10 for just first stage). One accumulator will do equivalent job but needs reset to start and it is slow i.e. result will be available after 2^20 samples gone through but for rms it should do.
Thank you kaz.
How can I implement such accumulator ?Is there a precompiled standard block or has to be written by hand ?
--- Quote Start ---
Thank you kaz.
--- Quote End ---
just a feedback register on clocke edge
sum <= sum + din; --din is I*I + Q*Q
you need to read final result, apply reset etc.
at the end you carefully get the mean of squares:
sum_trunc <= sum(n downto 20);
Then you decide for the square rooting issue
Thank you kaz.. I'm on it..
I've written the following code:
LIBRARY ieee; USE ieee.std_logic_1164.all; USE IEEE.std_logic_unsigned.all; ENTITY rms_estimator IS GENERIC (ACCBIT : INTEGER:=10); PORT( squared_abs : IN STD_LOGIC_VECTOR(31 DOWNTO 0); clk , clr : IN STD_LOGIC; squared_rms: OUT STD_LOGIC_VECTOR(31 DOWNTO 0); ready : out STD_LOGIC; END ENTITY rms_estimator; ARCHITECTURE logic OF rms_estimator IS signal sum : STD_LOGIC_VECTOR(ACCBIT+31 downto 0):=(OTHERS =>'0'); signal i : STD_LOGIC_VECTOR(ACCBIT downto 0):=(OTHERS =>'0'); BEGIN PROCESS(clk,clr) BEGIN IF(clr = '1') THEN squared_rms<=(OTHERS =>'0'); sum<=(OTHERS =>'0'); ready<='0'; i<=(OTHERS =>'0'); ELSIF rising_edge(clk) THEN if (i=2**ACCBIT) then squared_rms<=std_logic_vector(sum(ACCBIT+31 downto ACCBIT)); ready<='1'; else sum<= sum + unsigned(pad & squared_abs); i<=i+1; ready<='0'; squared_rms<=(others=>'0'); end if; END IF; END PROCESS; END ARCHITECTURE logic;
by the way the squared_rms is always at 'X' after the ready bit is set to '1'.. Any suggestions ?? I'm really stucked...
Thank you for your time!
some suggestions(not compiled)
ARCHITECTURE logic OF rms_estimator IS signal sum : unsigned(ACCBIT+31 downto 0):=(OTHERS =>'0'); signal i : unsigned(ACCBIT downto 0):=(OTHERS =>'0'); BEGIN PROCESS(clk,clr) BEGIN IF(clr = '1') THEN squared_rms <= (OTHERS =>'0'); sum <= (OTHERS =>'0'); ready <= '0'; i < =(OTHERS =>'0'); ELSIF rising_edge(clk) THEN if (i=2**ACCBIT - 1) then sum <= (others => '0'); squared_rms<=std_logic_vector(sum(ACCBIT+31 downto ACCBIT)); ready<='1'; i <= (others => '0'); else sum<= sum + unsigned(pad & squared_abs); -- what is pad? '0'? i<=i+1; ready<='0'; --squared_rms<=(others=>'0'); -- you may keep it latched end if; END IF; END PROCESS; END ARCHITECTURE logic;
Thank you kaz..
the 'pad' was not intended to be there it was written down in a previus attempt.
I have not updated the 'i' signal after it equals 2**ACCBIT because for testing pourpose I want to stop the sum when the ready bit is set.
By the way I always have XXXX... as output when the ready bit is set... mumble mumble..
It seems that the problem is in the recursion..
If i set:
sum<=32767+sum ==> the rms is 32767 as expected
try correct the width of squared_rms (should be less 10 bits).
edit: ignore this note as it is 32 bits so is abs
change sum type to unsigned
Dear kaz..
What I see is that at reset time:
sum=0;
Then at the first sum:
sum<=sum+unsigned(squared_abs) --squared_abs=2147483647 loaded from a .dat file
The result is XXXXXX and it mantains its value until the ready bit is set and de-set. After the de-setting it starts summing correctly from 0.
Thank you !
I've found the bug.. In the testbench i was not restting the input. Now it seems to work correctly. Thank you for the help kaz. You're a real guru !
Hello guys..
Now I'm working with RMS power estimation again.. I have two complex signals: sig1 and sig2.
I measure the RMS of sig1 and sig2 with a vhdl block and then via software I calculate: [(float) RMS(sig1)] / [(float) RMS(sig2)] with sig1>sig2.
I want that RMS(sig1) ~= RMS(sig2). So I tried to multiply sig2 with a 16-int-constant related to [(float) RMS(sig1)] / [(float) RMS(sig2)] and then take the 16-MSB after that multiplication. By the way I think I'm still missing something because I see funny results..
Any suggestions ?
Thank you! have a nice day !
