21611 Discussions
signal tap logic analyser problem!!! (STP)
anyone know is there any known issue in 12.1 and 12.1sp1 QII signal tap logic analyser?
1) First, when i click run analysis / autorun analysis, the signal tap keep remaining in "waiting for trigger" stage even i didn't sent any trigger signal
2) Without changing anything, i re-compile the design again.
3) Now, i click run analysis / autorun analysis again, and the signal tap is working!
I diff the the 2 fitter db file and found that there is a lot of different and i suspect maybe this different routing and placement make the stp working in 2nd compilation.
This make me very embarrassing because many times i need to re-compile the design for 2 times in order to make the stp working!
Anyone can help?
fpga89
Seem like no other user experience my problem? :(
