speed grade
if i'm using CYCLONE III EP3C40F484C6 - that means that its speed grade is 6 . right?
Fina.
Hi Fina,
Yes, of course,
You can see the Device Packaging Ordering Information in Cyclone III Handbook page 1-12..
Here the link : http://www.altera.com/literature/hb/cyc3/cyclone3_handbook.pdf
--- Quote Start ---
Fina.
--- Quote End ---
yes that's right. Keep in mind that it is not an exact indication of the max speed of the FPGA.
Kind regards
GPK
Thanks a lot for your answers :) :) :)
how can i know device max speed?
--- Quote Start ---
--- Quote End ---
sorry, I was not exact enough in my post. The timing for e.g. PLL's, I/O, I/O standards could be used to decide which speed grade do you need for your application. What I mean in my first post is was that the internal clock speed depends on your design. When you look into the datasheet you find e.g. a number for the clocktree speed ( C8 402 MHz). This doesn't mean that your design could run at this speed.
Sorry for any confusion.
Kind regards
GPK
Thank you !
