21611 Discussions
spi_command from Linux
Hy guys,
I'm using a CycloneV-SoC. In the FPGA, I have instanciated the Altera-SPI-Master-controller and connected it to the lightweight-H2F-bridge. Linux is running on the HPS. What should I do on the software side to access my SPI devices?
There is the altera_avalon_spi.c file that can be used on NIOS. Is there an equivalent file for HPS-ARM?
Hi Charly78,
There is an example in the 14.01 release for SPI: C:\altera\14.0.1\embedded\examples\software\Altera-SoCFPGA-HardwareLib-SPI... That should help you. Also, you can find the HWLib files in the directory as well: C:\altera\14.0.1\embedded\ip\altera\hps\altera_hps\hwlib\src\hwmgr
I hope that helps.
Sue
Hi scozart,
Those files are for the hard-coded SPI controllers of the HPS. My SPI controller is in FPGA implemented with the Altera MegaFunction.
I would like to get such HWLIB files and example but for SPI controller implemented in FPGA.
Hi Charly78,
This forum is for discussion of the HPS. For the soft IP, you need a different forum. Please post your question on the IP forum.
Sue
Sue -
Exact same question as Charly78, but I have an Altera 13.1 tree. Found the directory you referenced, but there wasn't any SPI material there. Do I have to download the 14.0 tree, or can I find the example on the Altera site ..?
John
Hi John,
We add new examples as we go along and we don't go backwards with verification. You can either download 14.0 (or wait a few days for 14.1) or try to retrofit the software your self to 13.1.
Sue
