21609 Discussions
stratix write2flash.exe & non-volitile configuration
I have a Stratix EP1S80 board which I would like to program the flash for non-volatile configuration. I am using Quartus 7.2 and can generate the .sof file for regular configuration via the parallel port masterblaster cable.
The problem is that for programming the flash (non-volatile) the manual has a procedure based on the serial port. This requires you to convert the .sof to a .hexout file (thats not a problem) and then downloading it to the fpga via the serial port using a utility in Quartus 4.2 (which I don't have) called Write2flash.exe.
My question is can I program this board with Quartus v7.2 (bypass write2flash)?
If not, does anyone know where I can get the Write2flash.exe file?
Thanks for any suggestions.
I guess, that the solution for the Stratix II DSP Board also applies to your board:
--- Quote Start ---
In the Stratix II EP2S60 DSP Development Board Data Sheet, in the Non-Volatile Configuration section, the Write2Flash utility is mentioned as a tool you can use to download user configuration data into the on-board flash. The new method is to use the Nios® II Flash Programmer through the Nios II SDK Shell.
Refer to the Nios II Flash Programmer User Guide for more detailed instructions on using the Nios II Flash Programmer.
--- Quote End ---
Thanks for the tip. I will check it out.
Tony
