HI
im looking to reduce configuration time in AS mode using SIVGX180 device & a serial flash. i cannot use CPLD or CPU for the configuration. the problem is that altera states that the DCLK serial clock to the flash is between 17 & 40 Mhz. that leaves worst case scenario of 17Mhz & a conf. time that is too long. is there a way to enter an external clock to the flash & FPGA? is there a way to ensure the 40Mhz clock? is there another way for conf. without the use of MAXII or CPU? THNXLink Copied
