Programmable Devices
21592 Discussions
synthesis of VHDL module
is it possible to synthesis of VHDL module if there is integer variables in the VHDL module ?
is it possible this module to be synthesized ?
library ieee; use ieee.std_logic_1164.all ; use ieee.std_logic_arith.all; entity clock is port ( clk, reset: inout std_logic; fast_clk : inout std_logic ; d: in std_logic_vector(5 downto 0) ; Q :out std_logic_vector(16 downto 0); enable : inout std_logic ; sec_bin : OUT STD_LOGIC_VECTOR(5 DOWNTO 0) ; min_bin : OUT STD_LOGIC_VECTOR(5 DOWNTO 0) ); end clock; architecture arch of clock is beginentity clock is port ( clk, reset: inout std_logic; fast_clk : inout std_logic ; d: in std_logic_vector(5 downto 0) ; Q :out std_logic_vector(16 downto 0); enable : inout std_logic ; sec_bin : OUT STD_LOGIC_VECTOR(5 DOWNTO 0) ; min_bin : OUT STD_LOGIC_VECTOR(5 DOWNTO 0) ); end clock; architecture arch of clock is begin process (clk, reset ) VARIABLE sec : INTEGER ; VARIABLE min : INTEGER ; begin if (clk'event and clk = '1') then if (enable = '1') then if (reset = '1') then sec := 0 ; min := 0; end if; if (sec < 60) then sec := sec +1; else sec := 0; if ( min < 60) then min := min +1; else min := 0 ; end if; end if ; sec_bin<=CONV_STD_LOGIC_VECTOR(sec,6) ; min_bin<=CONV_STD_LOGIC_VECTOR(min,6) ; end if ; end if; end process; end arch;
Theres no problem with that, but I feer you're not quite going to get what you expect.
Variables update immediatly, so sec_bin and min_bin are going to be the output of the adder direct rather than the output of the register holidng the values of sec and min.
To prevent this, move sec_bin and min_bin assignments to be before the variable assignments.
PS. why have you set clk, fast_clk, reset and enable ports to be inout rather than just in?
so the code must look like this
library ieee; use ieee.std_logic_1164.all ; use ieee.std_logic_arith.all; entity clock is port ( clk, reset: inout std_logic; fast_clk : inout std_logic ; d: in std_logic_vector(5 downto 0) ; Q :out std_logic_vector(16 downto 0); enable : inout std_logic ; sec_bin : OUT STD_LOGIC_VECTOR(5 DOWNTO 0) ; min_bin : OUT STD_LOGIC_VECTOR(5 DOWNTO 0) ); end clock; architecture arch of clock is begin process (clk, reset ) VARIABLE sec : INTEGER ; VARIABLE min : INTEGER ; begin sec_bin<=CONV_STD_LOGIC_VECTOR(sec,6) ; min_bin<=CONV_STD_LOGIC_VECTOR(min,6) ; if (clk'event and clk = '1') then if (enable = '1') then if (reset = '1') then sec := 0 ; min := 0; end if; if (sec < 60) then sec := sec +1; else sec := 0; if ( min < 60) then min := min +1; else min := 0 ; end if; end if ; end if ; end if; end process; end arch ;
no, keep the sec_bin and min_bin inside the clock assignments.
The best thing for you to do is just test it and simulate it until it works
