is it possible to synthesis of VHDL module if there is integer variables in the VHDL module ?
------------------------------- is it possible this module to be synthesized ?
library ieee;
use ieee.std_logic_1164.all ;
use ieee.std_logic_arith.all;
entity clock is
port (
clk, reset: inout std_logic;
fast_clk : inout std_logic ;
d: in std_logic_vector(5 downto 0) ;
Q :out std_logic_vector(16 downto 0);
enable : inout std_logic ;
sec_bin : OUT STD_LOGIC_VECTOR(5 DOWNTO 0) ;
min_bin : OUT STD_LOGIC_VECTOR(5 DOWNTO 0)
end clock;
architecture arch of clock is
beginentity clock is
port (
end clock;
begin
process (clk, reset )
VARIABLE sec : INTEGER ;
VARIABLE min : INTEGER ;
begin
if (clk'event and clk = '1') then
if (enable = '1') then
if (reset = '1') then sec := 0 ; min := 0; end if;
if (sec < 60) then sec := sec +1; else sec := 0; if ( min < 60) then min := min +1; else min := 0 ; end if; end if ;
sec_bin<=CONV_STD_LOGIC_VECTOR(sec,6) ;
min_bin<=CONV_STD_LOGIC_VECTOR(min,6) ;
end if ;
end if;
end process;
end arch;
Theres no problem with that, but I feer you're not quite going to get what you expect.
Variables update immediatly, so sec_bin and min_bin are going to be the output of the adder direct rather than the output of the register holidng the values of sec and min. To prevent this, move sec_bin and min_bin assignments to be before the variable assignments.- Mark as New
PS. why have you set clk, fast_clk, reset and enable ports to be inout rather than just in?
so the code must look like this
library ieee;
entity clock is
port (
end clock;
begin
begin
end if ;
end if;
end process;
end arch ;
no, keep the sec_bin and min_bin inside the clock assignments.
The best thing for you to do is just test it and simulate it until it works
