21611 Discussions
tcl for sending email when compilation finished
Is there any script known to man for sending an email saying the compilation was finished and the results?
If not, any idea how do I write such one?
Thx.
I haven't used it or really looked into it, but Altera is working on this feature:
http://www.altera.com/literature/ug/qsg_qii_sw_notification_center.pdf
If you can figure out how to send mail using a command, then you can use the Tcl exec command to issue that mail command.
For example, Google sending mail from the command-line and you'll get hits like ...
http://www.simplehelp.net/2008/12/01/how-to-send-email-from-the-linux-command-line/
This should work fine from Linux. Under Windows, you can probably use the command-line tools provided by Cygwin.
Cheers,
Dave
Ok, great! thanks.
