what actions count against the 3 time limit on rehosting?
I split a license off of our total number of floating license, then (unfortunately) created a license but had the wrong nic id so the license was not usable. I then created a temp license with the right nic id to make sure things would work. now the number of rehosts for that split off floating license is 0. Can I still assign the license to the computer on a permanent basis? Thanks in advanceLink Copied
you should probably talk to your local sales rep or call customer service at 800-SOS-EPLD to ask for some rehosts back
