hi,everyone
i need to find out the number of "1" in a input (a), now ,i thik i could add every bit of input (a) to get the resut, just like : assign b=a[0]+a[0]+a[1]+a[2]+a[3]+a[4]; -----code(1) so , if a==5'd10==5'b01010 then b=2 , it's right but ,now, the width of a is 2023 ,it is too large. so , for me ,it is a big trouble for me to write like code(1) ,it will cost too much time. so i wright like this: module jj(data_in,weight_out); parameter IN_WIDTH=10; input [IN_WIDTH-1:0 ] data_in; output [11:0] weight_out; reg [11:0] a; always @ (*) begin integer i; for(i=0;i<IN_WIDTH;i=i+1) a<=a+data_in[i]; end assign weight_out=a; endmodule but , this logic is not right.and a combinational loop occurs. any convenient and right method? thank you!Link Copied
I don't know Verilog In VHDL, you can use "variable" for counters you can use "function" or "procedure" to find out the number of '1'. This function will be something likefor(i=0;i<IN_WIDTH;i=i+1)
a<=a+data_in;
end
A nice way to do this is by writing a recursive function.
You first extend the vector with '0's so that the number of bits is a nice binary boundary, in the case you give 2048. You then call the recursive function which calls itself for the two halves. This continues until we have just 2 bits left. This will generate a nice tier of adders with the shortest delay and if you code it carefully minimal logic resources. Unfortunately I don't know Verilog (yet, but I ordered my first book on it). In VHDL it would look (somewhat) like this:
function number_of_bits( src : std_logic_vector) return natural is
begin
if (src'high = 0 ) then
-- we're down to a single bit
if (src(0) = '0') then
return 0 ;
else
return 1 ;
end if ;else-- we can split
return number_of_bits( upper_half(src) )
+ number_of_bits( lower_half(src) ) ;
end if
end function number_of_bits ;
Opposed to what a C-program or so would do, the HDL compiler will unroll the recursive loop into a nice tier of consecutive adders, in this case 11 layers and 2047 in total.
