Quartus infers RAM from the code, you don't have to change anything.
While Quartus may infer a RAM from this code, it's not using best practices.
First, you should be using ieee.numeric_std.all instead of std_logic_arith, and std_logic_unsigned. Second, your memory access process should have a sensitivity list and look something like this:
access_memory : process( clock )
begin
if( rising_edge(clock) ) then
dout <= ram( to_integer( addr ) ) ;
end if ;
end process ; -- access_memory
There are also some templates available inside of Quartus which may also be helpful.
--- Quote Start --- While Quartus may infer a RAM from this code, it's not using best practices. --- Quote End --- It actually does. Basically, I tried to focus on the original question. Further suggestions may be helpful, of course. I think, however, you should also give some explanation for what you regard as best practise. --- Quote Start --- First, you should be using ieee.numeric_std.all instead of std_logic_arith, and std_logic_unsigned. --- Quote End --- std_logic_unsigned may be regarded as bad practise. Personally, I dislike it too. But it simply introduces a Verilog-like behaviour in VHDL and may be appropriate for some simple applications. Regarding std_logic_arith, did you notice that all (or most) Altera VHDL IP is using it? --- Quote Start --- Second, your memory access process should have a sensitivity list and look something like this. --- Quote End --- It's fully legal VHDL code anyway. In an edge sensitive process, a sensitivity doesn't change the behaviour, neither in synthesis nor simulation. (Personally, I would use process(clock) at least to improve readbility and reserve wait until for simulation timing.) As another comment: after 1 ns is valid in simulation only and ignored in synthesis. And the rw / memsave logic seems dubious to me, but may serve a purpose anyway.
--- Quote Start --- Basically, I tried to focus on the original question. Further suggestions may be helpful, of course. I think, however, you should also give some explanation for what you regard as best practise. --- Quote End --- Agreed. Sorry about that. Thanks for clearing up my post. Just a few comments below. --- Quote Start --- std_logic_unsigned may be regarded as bad practise. Personally, I dislike it too. But it simply introduces a Verilog-like behaviour in VHDL and may be appropriate for some simple applications. Regarding std_logic_arith, did you notice that all (or most) Altera VHDL IP is using it? --- Quote End --- I do see Altera's IP using it, and I cringe every time I see them used. On a side note, I don't like how all of their IP ports which are clearly fed with signed or unsigned data don't expose this datatype. --- Quote Start --- It's fully legal VHDL code anyway. In an edge sensitive process, a sensitivity doesn't change the behaviour, neither in synthesis nor simulation. (Personally, I would use process(clock) at least to improve readbility and reserve wait until for simulation timing.) --- Quote End --- Agreed and understandable. VHDL is extremely versatile, but not necessarily always the easiest to read - so maintaining a clear intent is important when writing code.
Hi ,
I agree this code infers a ram + mif data but needs some tidy-up. The address bits 9 to 15 are not needed and are ignored by quartus. the signal ready seems unnecessary since ram is ready when enabled and one can expect when to rd/wr from that. Anyway if you prefer instaniation then use megawizard to generate a block of ram. kaz- Mark as New
thanks for the replies. really appreciate it
