21594 Discussions
video tracker EU PAL
In your opinion is Possibility to analyze a video pal and get the x and y offset of an object relative to the center of the screen?
i'm using cycloneII fpga
Yes. There are companies that build video trackers.
some of you did a similar project in this forum?
If you have a static camera it can be quite trivial:
Static image - current image = changes in the image, which are usually targets. The hard part is then finding and tracking the targets. It can require quite a bit of memory. You will need external memory for the frame buffering.
The solutions Ive seen use a processor and FPGA. The FPGA does the image pre-processing with the processor taking the thresholded image and tracking the targets.
