21615 Discussions
weird behaviour of fitter in quartus for SDRAM project
omar_ibrahim
I've been working on SDRAM controller project using verilog using cyclone v 5cefa5f23i7.
The SDRAM have four bank , 3 cas latency and 166 Mhz clock.
I start design with a goal of having lowest possible latency for controller but as i expect timing failure start  appearing at first compile , so i start debugging and change the hdl code
I also use compile at aggressive performance setting,
the main problem is the io is far from other so the routing delay is huge (up to 5ns) leaving small roam for logic delay.
here is the code it not complete and i still beginner
module controller(
input clk,clk_2,rst,
inout wire [31:0] data_bus,
output reg [12:0] addr_out,
output reg [1:0] bank_out,
output reg [3:0] DQ,
output reg cke,cas,ras,we,cs,
output wire clk_out,
		//control_port
input wire [23:0] addr_in,
input wire [31:0] data_w_in,
output reg [31:0] data_r_in,
input wire write_in,read_in,
output reg ready,
output reg [3:0] busy
integer i,j,k,h;
integer num [3:0];
integer num_2 [3:0];
clock_out	clock_out_inst (
	.datain_h (1'b1),
	.datain_l (1'b0),
	.outclock (clk_2),
	.dataout (clk_out)
///////////////////sync
always_ff @(posedge clk or negedge rst)
if(~rst)
	data_r_in <= 0;
else
	data_r_in <= data_bus;
reg act_write = 0;
reg [1:0] read_delay = 3;
always_ff @(negedge clk_2 or negedge rst)//output enable
if(~rst)
	act_write <= 0;
else
	act_write <= (read_delay<2) ? 0 : 1 ;
reg [31:0] data_out = 0;
assign data_bus = act_write ? data_out : 32'bz;
////////////////end_sync
////////////////////////////////////main_state_machine
reg [1:0] main_s = 0;
parameter initial_ = 0 ,work = 2'h1 ,refresh = 2'h2;
reg [1:0] counter = 0;
reg [3:0] ref_delay = 0;
reg [11:0] ref_counter = 0;
reg [3:0] ref_act = 0;
initial begin
addr_out = 0;
bank_out = 0;
data_r_in = 0;
ready = 0;
cke = 1;
cas = 1;
ras = 1;
we = 1;
cs = 1;
DQ = 4'hf;
end
///////////////////////////////////comb_logic_registers
reg [1:0] main_s_wire;
reg [1:0] counter_wire;
reg [3:0] ref_delay_wire;
reg [11:0] ref_counter_wire;
reg [3:0] ref_act_wire;
reg [12:0] addr_out_wire;
reg [1:0] bank_out_wire;
reg [3:0] DQ_wire;
reg [31:0] data_out_wire;
reg [1:0] read_delay_wire;
reg ready_wire;
reg cke_wire;
reg cas_wire;
reg ras_wire;
reg we_wire;
reg cs_wire;
counter_wire = counter_wire;
ref_delay_wire = ref_delay;
addr_out_wire = addr_out;
bank_out_wire = bank_out;
DQ_wire = DQ;
cke_wire = cke;
cas_wire = cas;
ras_wire = ras;
we_wire = we;
cs_wire = cs;
///////////////////////////////////bank_state_machine
reg [1:0] state [3:0];
parameter idle = 2'h0 ,active = 2'h1 ,read_write = 2'h2 ,precharge = 2'h3;
//////////////////////instructure coder
reg [1:0] ins [3:0];
parameter active_i = 2'h0 ,read_i = 2'h1 ,write_i = 2'h2 ,pre_charge_i = 2'h3;
reg [3:0] ins_r [3:0];
//////////////////////delay control
reg [3:0] delay [3:0];//active to write or read to precharge
reg delay_pre [3:0];	 //write to precharge
//////////////////////data_latch
reg [31:0] data [3:0];
reg [21:0] addr [3:0];
parameter read_con = 0 , write_con = 1'b1;
reg r_w [3:0];
/////////////////////globa_variables
reg [3:0] delay_ab = 0;  //delay from read or write in different bank
reg [1:0] global_act = 0;//delay from active to active in diffrent bank
reg [3:0] run = 0; //reg to control "chip select"
always_comb begin
if(ref_counter >= 1200)begin
	ref_counter_wire = 0;
	ref_act_wire = ref_act+1;
	end
else begin
	ref_counter_wire = ref_counter+1;
	ref_act_wire = ref_act;
	end
if(read_delay == 0)begin
	ready_wire = 1;
	read_delay_wire = 3;
	end
else begin
	ready_wire = 0;
	if(read_delay < 3)
		read_delay_wire = read_delay-1;
	else
		read_delay_wire = read_delay;
	end
case(main_s)
initial_:begin
			counter_wire[0] = 1;
			counter_wire[1] = counter[0];
			ras_wire = 0;//precharge all banks
			we_wire = 0;
			bank_out_wire = 0;//mode register set
			if(counter[0])begin
				cas_wire = 0;
				addr_out_wire = 13'b0001000110000;//refer to mode register table
				end
			else begin
				cas_wire = 1'b1;
				addr_out_wire = 13'b0010000000000;//bank precharge
				end
			if(counter[1])begin
				ref_act_wire = 8;
				main_s_wire = refresh;
				cs_wire = 1;
				end
			else begin
				main_s_wire = main_s;
				cs_wire = 0;
				end
			data_out_wire = data_out;
			DQ_wire = DQ;
			cke_wire = cke;
			end
work:begin/////normal_operatoin
			counter_wire = counter;
			DQ_wire = DQ;
			cke_wire = cke;
			addr_out_wire = addr_out;//should be removed
		if(ins_r[0][2] == 1)begin // here is the problem
			data_out_wire = data[0];
			end else
		if(ins_r[1][2] == 1)begin
			data_out_wire = data[1];
			end else
		if(ins_r[2][2] == 1)begin
			data_out_wire = data[2];
			end else
			data_out_wire = data[3];
		if((ins_r[0][0] == 1)|(ins_r[1][0] == 1)|(ins_r[2][0] == 1)|(ins_r[3][0] == 1)|(ins_r[0][2] == 1)|(ins_r[1][2] == 1)|(ins_r[2][2] == 1)|(ins_r[3][2] == 1))begin//active
			we_wire = 1;
			end else
			we_wire = 0;
			if((ins[0] == active_i)&(run[0]))
				addr_out_wire = addr[0][12:0];
			else
			if((ins[1] == active_i)&(run[1]))
				addr_out_wire = addr[1][12:0];
			else
			if((ins[2] == active_i)&(run[2]))
				addr_out_wire = addr[2][12:0];
			else
			if((ins[3] == active_i)&(run[3]))
				addr_out_wire = addr[3][12:0];
			else
			if((ins[0] == write_i)&(run[0]))
			else
			if((ins[1] == write_i)&(run[1]))
			else
			if((ins[2] == write_i)&(run[2]))
			else
			if((ins[3] == write_i)&(run[3]))
			else
			if((ins[0] == read_i)&(run[0]))
			else
			if((ins[1] == read_i)&(run[1]))
			else
			if((ins[2] == read_i)&(run[2]))
			else
			if((ins[3] == read_i)&(run[3]))
			else
			if((ins[0] == pre_charge_i)&(run[0]))
			else
			if((ins[1] == pre_charge_i)&(run[1]))
			else
			if((ins[2] == pre_charge_i)&(run[2]))
			else
			if((ins[3] == pre_charge_i)&(run[3]))
		if((ins_r[0][0] == 1)|(ins_r[1][0] == 1)|(ins_r[2][0] == 1)|(ins_r[3][0] == 1))begin//active
			cas_wire = 1'b1;
			ras_wire = 0;
			if(ins_r[0][0] == 1)begin
				bank_out_wire = 0;
				end else
			if(ins_r[1][0] == 1)begin
				bank_out_wire = 1;
				end else
			if(ins_r[2][0] == 1)begin
				bank_out_wire = 2;
				end else
				bank_out_wire = 3;
			end
		else
		if((ins_r[0][2] == 1)|(ins_r[1][2] == 1)|(ins_r[2][2] == 1)|(ins_r[3][2] == 1))begin//write
			ras_wire = 1'b1;
			cas_wire = 0;
				bank_out_wire = 0;
				end else
				bank_out_wire = 1;
				end else
				bank_out_wire = 2;
				end else
				bank_out_wire = 3;
			end
		else
		if((ins_r[0][1] == 1)|(ins_r[1][1] == 1)|(ins_r[2][1] == 1)|(ins_r[3][1] == 1))begin
			ras_wire = 1'b1;
			cas_wire = 0;
			read_delay_wire = 2'd2;
			if(ins_r[0][1] == 1)begin
				bank_out_wire = 0;
				end else
			if(ins_r[1][1] == 1)begin
				bank_out_wire = 1;
				end else
			if(ins_r[2][1] == 1)begin
				bank_out_wire = 2;
				end else
				bank_out_wire = 3;
			end
		else
		if((ins_r[0][3] == 1)|(ins_r[0][3] == 1)|(ins_r[0][3] == 1)|(ins_r[0][3] == 1))begin
			ras_wire = 0;
			cas_wire = 1'b1;
			if(ins_r[0][3] == 1)
				bank_out_wire = 0;
				else
			if(ins_r[1][3] == 1)
				bank_out_wire = 1;
				else
			if(ins_r[2][3] == 1)
				bank_out_wire = 2;
				else
				bank_out_wire = 3;
			end
		else begin
			ras_wire = ras;
			cas_wire = cas;
			if(ref_act!=0)
			else
			end
		if(run[0]|run[1]|run[2]|run[3])
			cs_wire = 0;
		else
			cs_wire = 1;
		end
refresh: begin///////////////////////refresh_part
			cas_wire = 0;
			ras_wire = 0;
			we_wire = 1;
			if(ref_delay == 0)begin
				if(ref_act!=0)begin
					ref_delay_wire = 9;
					ref_act_wire = ref_act-1'd1;
					cs_wire = 0;
					end
				else begin
					main_s_wire = work;
					cs_wire = 1;
					end
				end
			else begin
				ref_delay_wire = ref_delay-1;
				cs_wire = 1;
				end
			DQ_wire = DQ;
			cke_wire = cke;
			end
default: main_s_wire = initial_;
endcase
end
if(~rst)begin/////////////////reset
	main_s <= initial_;
	counter <= 0;
	cs <= 1;
	ras <= 1;
	cas <= 1;
	we <= 1;
	bank_out <= 0;
	ref_act <= 0;
	ref_delay <= 0;
	read_delay <= 3;
	ref_counter <= 0;
	addr_out <= 0;
	data_out <= 0;
	ready <= 0;
	DQ <= 4'hf;
end else begin////////////end_reset
	main_s <= main_s_wire;
	counter <= counter_wire;
	cs <= cs_wire;
	ras <= ras_wire;
	cas <= cas_wire;
	we <= we_wire;
	bank_out <= bank_out_wire;
	ref_act <= ref_act_wire;
	ref_delay <= ref_delay_wire;
	read_delay <= read_delay_wire;
	ref_counter <= ref_counter_wire;
	addr_out <= addr_out_wire;
	data_out <= data_out_wire;
	ready <= ready_wire;
	DQ <= DQ_wire;
end
////////////////////////////////////////////////////////banks/////////////////////////////////////
initial
for(i = 0; i <= 3; i = i+1)begin
state [i] = idle;
ins [i] = active_i;
delay [i] = 4'd9;
delay_pre [i] = 0;//fix
data[i] = 0;
addr[i] = 0;
r_w[i] = read_con;
busy[i] = 1;
ins_r[i] = 4'h0;
end
wire [8:0] colum = addr_in [8:0];
wire [12:0] row = addr_in [21:9];
wire [1:0] bank =  addr_in [23:22];
always_ff @(negedge clk or negedge rst)
	for(j = 0; j <= 3; j = j+1)begin
	k = j;
	if (k == i)
		k = k+1;
	if(k == 4)
		k = 32'd0;
	num[j]=k;
end
if (~rst) begin
state[i] <= idle;
ins[i] <= active_i;
data[i] <= 0;
addr[i] <= 0;
r_w[i] <= read_con;
busy[i] <= 1;
ins_r[i] <= 0;
///////////////delays
delay[i] <= 4'd9;
delay_pre[i] <= 0;
///////////////global
global_act <= 0;
delay_ab[i] <= 0;
run[i] <= 0;
end/////////////////////end reset
else begin
if((read_in|write_in)&(ref_act == 0))//fix fix
	global_act <= 2'd3;
else
	if(global_act!=0)
		global_act <= global_act-1;
	else
		global_act <= global_act;//i don't know why it give error when i delete this line
case(state[i])
	idle:begin							//idle
			////////////////////////////////counter_part
			if(delay[i]!=0)
				delay[i] <= delay[i]-1'd1;
			if(delay_pre[i]!=0)
				delay_pre[i] <= 0;
			if(delay_ab[i]!=0)
				delay_ab[i] <= 0;
			////////////////////////////////counters_end
			if (( bank == i ) & ( read_in | write_in ) & ( ref_act == 0 ))begin
				data[i] <= data_w_in;
				addr[i] <= {colum,row};
				r_w[i] <= ~read_in;
				state[i] <= active;
				busy[i] <= 1;
				end
			else begin
				if(ref_act == 0)
					busy[i] <= 0;
				end
			run[i] <= 0;
			end
	active:begin						//active
			if(delay_pre[i] != 0)
				delay_pre[i] <= 0;
			if(delay_ab[i] != 0)
				delay_ab[i] <= 0;
			if((delay[i] == 0)&(global_act == 0))begin
				delay[i] <= 4'd9;
				ins[i] <= active_i;
				ins_r[i] <= 4'b0001;
				run[i] <= 1;
				addr[i][12:0] <= {4'h0,addr[i][21:13]};
				state[i] <= read_write;
				end
			else begin
				run[i] <= 0;
				if(delay[i] != 0)
					delay[i] <= delay[i]-1;
				end
			end
	read_write: if (r_w[i] == read_con) begin				//read
			if(delay[i] != 0)
			if(delay_pre[i]!=0)
				delay_pre[i] <= 0;
			if((delay[i] <= 4'd7)&({delay_ab[num[0]],delay_ab[num[1]],delay_ab[num[2]],delay_ab[num[3]]} ==  0))begin
				ins[i] <= read_i;
				ins_r[i] <= 4'b0010;
				state[i] <= precharge;
				delay_ab[i] <= 1'b1;
				run[i] <= 1;
				end
			else begin
				run[i] <= 0;
				delay_ab[i] <= 0;
				end
			end
		else begin											//write
			if(delay[i]!=0)
			if((delay[i] <= 4'd7)&({delay_ab[num[0]],delay_ab[num[1]],delay_ab[num[2]],delay_ab[num[3]]} ==  0)&(read_delay!=1))begin
				ins[i] <= write_i;
				ins_r[i] <= 4'b0100;
				delay_pre[i] <= 1'b1;
				run[i] <= 1;
				end
			else begin
					run[i] <= 0;
					delay_pre[i] <= 0;
					delay_ab[i] <= 0;
				end
			end
	precharge:begin					//pre_charge
			delay_pre[i] <= 0;
			delay_ab[i] <= 0;
			run[i] <= 0;
			if((delay[i] <= 2)&(~delay_pre[i]))begin
				ins[i] <= pre_charge_i;
				ins_r[i] <= 4'b1000;
				delay[i] <= 4'd2;
				state[i] <= idle;
				run[i] <= 1;
				end
			else begin
				run[i] <= 0;
				if(delay[i]!=0)
				end
			end
	default:state[i] <= idle;
endcase
end end
endmodule
the problem in data_out register at line 189 the fitter have two option to do that
first is to use 7 input alm to read 3 ins_r register and four data register.
second is use 5 input with help of multiplexer at input of data_out register.
the second option is better and this what fitter choose but for some reason the fitter use another alm to making the multiplexer which lead to bigger delay and timing failaure
Iam using io reg so iam sure the multiplexer is free to use
Thanks in advance and sorry for any error in typing
sstrell
Any reason why you are not using the included EMIF IP instead of trying to reinvent the wheel?
AdzimZM_Intel
Hi omar_ibrahim,
Thank you for using Intel Community.
I'm not familiar with your module and not much I can help you here unless you're using Intel EMIF IP.
I can provide the Example Design for the EMIF IP later.
Adzim
AdzimZM_Intel
I'm attaching the example design for the EMIF IP.
The design should be a good reference to you.
AdzimZM_Intel
We do not receive any response from you to the previous reply that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
