21615 Discussions
what do i need to run a FPGA chip
I bought a cyclone II EP2C20Q240 , and i want to download a simple program in it by JTAG, what do i need?
NOW ,i have connect the vcc=3.3v and GND to the chip,the 50MHZ crystal is also ok; And other connections follow the configuration handbook at page 670 JTAG configuration of a sigle device using a download cable ;
But why i can't download the program to the FPGA by Quartue II ?
anyother connections do i need?
Thanks for your help!
Here is my circuit;
http://hiphotos.baidu.com/wswuda2007/pic/item/bfae41cbd9c13e5692457e8d.jpg
http://hiphotos.baidu.com/wswuda2007/pic/item/598f21c9b4e24f4501e9288d.jpg
http://hiphotos.baidu.com/wswuda2007/pic/item/e08f2341110f9bd7b2b7dc8d.jpg
Core voltagle? PLL (if used) voltage? IO voltage?
Some details on which error gives the download procedure may help.
when i download the program with a usb-blaster by quartus II ,and click the start.it showed the error" can't access the JTAG chain".
--- Quote Start ---
--- Quote End ---
The vccio1-8 is right and vccint is also ok, there is no ppl. what's the core voltage?
--- Quote Start ---
--- Quote End ---
I usually use QuartusII under Linux, errors like this are commons if you do not have the permissions on the /proc/bus/usb/ directory, in particular to the one containing the USB Blaster device.
--- Quote Start ---
--- Quote End ---
I think the quartus II is ok. Because when i download the program on DE2 by usb , it runs well. But I'm not sure about the connections of the cycloneII . All i did is just connect the source, 50MHZcrystal, and the jtag configuration as followed.
http://img694.ph.126.net/xqpymzkjlp_z-u930livlw==/1152358554654692147.jpg
Anyother process do i need?
Hmm, can't see the images. Could you upload to a different host? (say tinypic.com)
I fell so sory, but i have corrected the problem .Can you see the pictures now?
