Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
Adding additional raid disk 5
Sal1368
Good morning. I have a system with an Asus WS Z390 Pro MB and a Raid 5 with 4 Samsung SSDs. I wanted to add another Samsung SSD to the Raid, but the Intel application Product Version 18.1.1037.0 does not allow me to insert SSD inside the Raid 5 volume.
Attached are the program screens and SSU logs
How can I proceed?
n_scott_pearson
The most likely cause of this is an unsupported hardware configuration. Note the following (from board specs):
1. M2X4_1 socket shares lane with the SATA6G_56 connector:
. When using the M2X4_1 socket is PCIe or SATA device, the SATA_56 connector will be disabled.
. When using the SATA_56 connector, no device must be connected to the M2X4_1 connector.
2. M2X4_2 socket shares lane with the U.2_2 and SATA6G_12 connector:
. When using the M2X4_2 socket is PCIe or SATA device, the U.2_2 connector will be disabled.
. When using the M2X4_2 socket is SATA device, the SATA6G_12 connector will be disabled.
. When using the U.2_2 connector, no device must be connected to the M2X4_2 socket.
Hope this helps,
Sal1368
Thanks for your help.
There is nothing connected to the M2 connectors. Could it be due to the smaller capacity of the SSD compared to the Raid SSDs?
n_scott_pearson
AFAIK, the size shouldn't matter. If the SATA connectors are from the chipset, the drive plugged in should be useable with RST.
Sal1368
Hi, I managed to test what we said. I installed a new SSD with the same capacity as those already present in the Raid 5. The software immediately recognized the new SSD and let me insert it into the Raid without problems. Probably some bios update allowed the problem to be bypassed. Everything OK. Thanks for the support.
