Rapid Storage Technology
Intel® RST, RAID
2200 Discussions
BSOD Stop Error 0x0000007B after enabling RAID mode in BIOS
TCart5
I have just installed an image of my old PC onto a new PC (Dell optiplex 7040). Both the old and new have Intel RAID chips and the Windows 7 OS drives are configured for RAID1.
When I boot up the new PC I get stop error 0x0000007B.
This appears to be the result of the storage driver - https://support.microsoft.com/en-us/kb/316401 https://support.microsoft.com/en-us/kb/316401.
This is what I have tried to resolve the issue:
1. I have tried installing the current Intel RAID RST driver before installing the image, but when the imaging is completed and I reboot, Windows still blue screens with the same error.
2. I have also tried to reset the disk to non-RAID (http://www.intel.com/content/www/us/en/support/boards-and-kits/000006188.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000006188.html), but keep RAID mode enabled in the BIOS and reboot, but still get the same error.
3. I can't boot into Safe Mode, it also blue screens with the same error.
If I configure the disks as AHCI mode, it boots okay. I can then uninstall the old drivers and install the newest Dell Intel RST drivers package and reboot and it's fine with the disks set to AHCI mode. But then If I configure the disks back to RAID mode in the BIOS, it blue screens with the same error.
I have even tried booting up in AHCI mode, installing the current Intel RST drivers from Dell, and correctly configured the registry keys (as listed in this https://support.microsoft.com/en-au/kb/922976 MS Technet article) before taken a backup image again. Then I reboot, set the BIOS to RAID mode, configure the RAID volume, clean the disk and format the volume with diskpart, and restore the new image that has the new IntelRST drivers to the RAID volume. But when I reboot after finishing the image it blue screens with the same error.
I have tried a ridiculous number of other suggestions from around the web including:
https://support.microsoft.com/en-au/kb/922976 https://support.microsoft.com/en-au/kb/922976
http://www.dell.com/support/article/ed/en/eddhs1/SLN285045 Registry Fix to Migrate from ATA Mode to AHCI Mode or RAID On Mode in Windows XP, Windows Vista or Windows 7 | Dell Euro…
https://social.technet.microsoft.com/Forums/windows/en-US/19c703a4-f52a-4b90-8a8c-fd80cbaf9c7a/windows-7-no-boot-stop-0x0000007b-and-classpnpsys-problem?forum=w7itprogeneral Windows 7 No Boot - STOP: 0x0000007B and CLASSPNP.SYS problem?
https://technet.microsoft.com/en-us/library/cc785339%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396# BKMK_9 Troubleshooting specific Stop messages
https://support.microsoft.com/en-us/kb/324103 https://support.microsoft.com/en-us/kb/324103
http://www.justandrew.net/2009/10/stop-0x0000007b-on-p2vd-windows-7.html Andrew's Cheap Thrills: STOP 0x0000007B on P2V'd Windows 7
How can I get the RAID setting to work?
KL2
Valued Contributor I
Is the RAID 1 volume created on your old PC a Windows RAID (created in Disk Management)? Or, if it's an Intel Matrix / Rapid Storage Technology RAID volume, which chipset is it, and which version of the Matrix / RST driver is in use?
This statement makes me think that AHCI is enabled when you're installing the RST package. Installing the RST package installs either the AHCI driver or RAID driver depending on what is currently enabled in your BIOS. It will not install both.
The inbox Windows 7 driver for Intel Matrix RAID is version 8.6.2.* (last four digits depend on how updated your Win7 installation is). When you follow that Microsoft procedure, you're just enabling iastorV (the Windows 7 inbox driver), and it surely does not support 100 Series Intel chipsets.
Which environment are you running diskpart in? WinPE 3 / 4 / 5, Win7, Win8?
If the same environment you're using contains DISM, you can add the correct driver (RST 14.8.x.x iaStorAC.inf) to the newly imaged PC using that.
E.G. Say the Windows volume of the PC you want to add the RAID driver to is C: and the driver files (iaStorAC.inf, iaStorAC.cat, iaStorAC.sys, iaStorF.sys x64) are located in C:\Temp
DISM /image:C:\ /add-driver /driver:C:\Temp\iaStorAC.inf
Then reboot, and the driver should be enabled by default. More DISM add driver info here: https://technet.microsoft.com/en-us/library/dd744355(v=ws.10).aspx https://technet.microsoft.com/en-us/library/dd744355(v=ws.10).aspx
If not, you can load the registry hive offline and change the iastorA 'start' value
Hi TeeC,
Let us know if Gize2 suggestion helps you.
Hellen.
TCart5
Hi Gize2,
Thanks for that. Apologies for the delay getting back to you.
TLDR: I ended up doing a clean build of Windows 10.
But in answer to your replies :
Both RAID volumes (old and new) created pre-boot through Intel RST.
The old PC is an Intel Q87 Express (RST v) , the new PC is an Intel Q170 (i've tried it with the .
When I say "tried installing the current Intel RAID RST driver before installing the image", I mean that:
I created the RAID volume (pre boot), so the BIOS is configured to RAID, not AHCI
Then booted from the EaseUs bootCD (WinPE environment)
Even though I could see the RAID volume, I installed the RST drivers.
Note: I also tried both not installing the RST driver as EaseUs could already see the RAID volume.
Note: EaseUs is supposed to do a bare metal restore.
That and your statement about RST only installing the relevant drivers for the current mode explains why it isn't working.
I'm pretty sure I tried using DISM to inject the drivers, but also couldn't get it to work either, with the resultant same blue screen error.
I even injected the drivers into a Windows7 boot disk (both with DISM and with NTLite), but neither couldn't see the RAID volume.
At this point I gave up and rebuilt with Windows 10.
Muchas gracias for your help!
Hi TeeC,
Thanks for the answers, if there is anything else you need, please let me know.
Hellen.
