Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
Can not enable Dynamic Storage Accelerator via CLI (14.8.0.1042)
DPokr1
Hello.
In connection to this /thread/100159 tread. I still can't solve the issue (BIOS updated since then, Windows updated since then, tried NUC 14.10.0.1016 driver and software, but no luck anyway).
In short: I got i7-4770 on Z97, Windows 10 x64 1086.318, driver and software version of 14.8.0.1042. At some point Dynamic Storage Accelerator stopped working. Did a lot of messing with drivers trying to solve the issue but with no success.
For now I got Dynamic Storage Accelerator enabled in BIOS, I got drivers and RST software installed. But Dynamic Storage Accelerator does not work.
So I tried rst cli (in elevated cmd) in order to investigate the problem:
K:\rstcli>rstcli64 -I
--CONTROLLER INFORMATION--
Name: Intel Chipset SATA RAID Controller
Type: AHCI
Supported RAID: 0,1,5,10
Max Disks/Array: 6
HW Information:
Vendor ID: 0x8086
Device ID: 0x2822
HW Revision: 0
Dynamic Storage Accelerator: Disabled
than I did
K:\rstcli>rstcli64 --dynamic-storage-accelerator true
0
it says executed successfully, but still got
Type: AHCI
Max Disks/Array: 6
HW Information:
Vendor ID: 0x8086
Device ID: 0x2822
HW Revision: 0
I also tried
K:\rstcli>rstcli64 --dynamic-storage-accelerator false
REQUEST_FAILED: Request is formatted correctly but failed to execute.
Dynamic Storage Accelerator is already Disabled
1
For some reason it thinks DSA is always off, no matter I force it to switch on.
Why I can not enable DSA? What could be a problem? Is there anyway to solve it without a complete Windows reset/reinstall?
Thanks anyone in advance.
BPAVO
Hello, an error was introduced with version "14.8.0.1042" in the register. So AFTER you activate the DST in the gui menu (or rstCLI) :
go to "regedit"
locate "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStorA\Parameters\Device"
and change value : "LakeTinyReg" with dword (32bits) = "00000103" to "LakeTinyReg" with dword = "00010003" :
And after that, You are able to have always active DST on SHUTDOWN, RESTART, HIBERNATION....
This is a great post, thank you @ beyondTheTruth for your input about this matter.
Allan.
