Rapid Storage Technology
Intel® RST, RAID
2200 Discussions
Enable Acceleration is not available in IRST User Interface
JHumm
rsThe enable acceleration option isn't listed at all. Why?
Board is a DZ68VZ
RST RAID driver version 12.6
RAID 1 volume is consistent with no errors and is in continuous update mode.
I have looked for a list of reasons why the UI would fail and haven't found anything. Is there a utility that can examine the system and provide the reason why acceleration is not an option?
This is my RAID volume:
Description Disk drive
Manufacturer (Standard disk drives)
Model Intel Raid 1 Volume SCSI Disk Device
Bytes/Sector 512
Media Loaded Yes
Media Type Fixed hard disk
Partitions 2
SCSI Bus 0
SCSI Logical Unit 0
SCSI Port 2
SCSI Target ID 1
Sectors/Track 63
Size 931.50 GB (1,000,194,048,000 bytes)
Total Cylinders 121,600
Total Sectors 1,953,504,000
Total Tracks 31,008,000
Tracks/Cylinder 255
Partition Disk # 0, Partition # 0
Partition Size 100.00 MB (104,857,600 bytes)
Partition Starting Offset 1,048,576 bytes
Partition Disk # 0, Partition # 1
Partition Size 901.37 GB (967,835,648,000 bytes)
Partition Starting Offset 105,906,176 bytes
This is the new SSD I am trying to add:
Model INTEL SSDSC2CT180A4 SCSI Disk Device
Bytes/Sector 512
Media Loaded Yes
Partitions 1
SCSI Bus 5
SCSI Logical Unit 0
SCSI Port 2
SCSI Target ID 0
Sectors/Track 63
Size 167.68 GB (180,043,153,920 bytes)
Total Cylinders 21,889
Total Sectors 351,646,785
Total Tracks 5,581,695
Tracks/Cylinder 255
Partition Disk # 1, Partition # 0
Partition Size 167.55 GB (179,909,427,200 bytes)
Partition Starting Offset 135,266,304 bytes
Silvia_L_Intel1
Hello Poolman,
Please check there are not partitions on your SSD. If there is any, you would need to delete the volume or the partition. Do not format the drive.
http://download.intel.com/support/chipsets/sb/intel_smart_response_technology_user_guide.pdf http://download.intel.com/support/chipsets/sb/intel_smart_response_technology_user_guide.pdf
Regards.
Silvia_L_Intel1
Hello Poolman,
Regards.
JHumm
I found a boot manager partition that is 100MB in addition to the Windows 7 partition. From your response, I assume I need to get rid of it and then run startup repair on Windows 7 to insure it will start properly. Do you agree?
thanks in advance
Silvia_L_Intel1
Poolman,
Where do you have Windows 7 installed?
Because, if you have the OS installed on the SSD, you cannot use it to accelerate the RAID. To accelerate the RAID, the SSD needs to be empty.
Please go to "Disk management" and check if the SSD has any partition. In order to have the "accelerate" option on the RST, all the space on the SSD needs to be unallocated.
Please let me know,
JHumm
Yes, I have Windows 7.
I had a boot partition for it. I removed it and now the only partition in my RAID 1 array is the Windows 7 partition.
What's next?
JHumm
Okay - I figured it out.
My RAID 1 array was in recovery mode. After I modified it to be a RAID 1 volume again, the acceleration option appeared when I clicked on performance.
thank you for your help.
Silvia_L_Intel1
No problem! I'm glad to know you were able to fixed it.
