Rapid Storage Technology
Intel® RST, RAID
Comunicados
2196 Discussões
Error Code 0xA0080000 and 0xA00906B3 when Windows 11 Dev Drive mounted
LdBeth
Principiante
6.530 Visualizações
With RST driver 18.7.6.1919.3 and Windows 11 23H2 build 22631.4112, whenever after a Windows Dev Drive has been mounted, start Intel Optane Memory and Storage Management will fail to start with these errors, until the Dev Drive been unmounted and reboot.
17 Respostas
DeancR_Intel
Moderador
6.412 Visualizações
Hi LdBeth,
Thank you for posting in the community! Apologies for the delay on my response.
Please try the following steps on these links for reference:
Error Codes 0xA0070021, 0xA0080003, 0xA0080005, 0xA0080006, or... (intel.com)
Error Code 0xA00906B3 - Intel® RST Service Disruption
Let us know if you encountered any issues.
Dean R.
LdBeth
Principiante
6.384 Visualizações
Hi, I have read the support articles and it did not solve the problem I have.
The Inte Optane Memory and Storage Management itself works fine, it is just whenever Windows Dev Drive is mounted the app would fail to start, and the Intel Optane + HDD device seems still work, and after a reboot without mounting the dev drive the management app can start normally again. Reinstall RST driver does not fix that, and the BIOS settings are all right. Both the BIOS from vendor and the chipset driver is also the latest (Z590-C/ac from ASRock if that matters).
Also, I believe the second article is quite outdated as I didn't find any RstMwRpc services on Windows 11, and the closest thing I can find is Intel(R) Optane(TM) memory service and start that manually gives a "it starts and then stopped" message and does not fix the management app.
From what I observed, it is Windows Dev Drive conflicts with the Optane Memory Management App.
DeancR_Intel
Moderador
6.319 Visualizações
Hi LdBeth,
I suggest trying this step. Here's the link for reference:
How to Remove Intel® Rapid Storage Technology (Intel® RST)...
Try to install it again and let us know if you encountered any issues.
Dean R.
DeancR_Intel
Moderador
6.240 Visualizações
Hi LdBeth,
Dean R.
LdBeth
Principiante
6.217 Visualizações
Hi, Dean
I have disabled Optane Memory volumes and revert back to AHCI in BIOS, there is no VMD support from the motherboard, the problem persists that is whenever the Windows Dev Drive is mounted the Intel Optane Memory and Storage Managment app failed to start and gives the same two errors.
LdBeth
DeancR_Intel
Moderador
6.130 Visualizações
Hi LdBeth,
This is an acknowledgement message, do please wait for our higher ups working on this to be able to provide a resolution to your request.
Please do give us more time to this, we will get back to you possibly when we have the necessary information with regards to your issue.
Dean R.
DeancR_Intel
Moderador
6.092 Visualizações
Hi LdBeth,
Just to add, Windows Dev Drive is a functionality that Microsoft developed as part of Windows 11.
To be clear, is the error codes you're referring to is with Intel Optane Memory and Storage Management software or Windows Dev Drive?
You mentioned that Intel Optane and + HDD device seems to work, does it mean that you have an Intel Optane SSD and accelerated the HDD with it via Intel RST driver? Or do you have a RAID array setup via Intel RST?
To better understand your system's configuration, we kindly request that you download the Intel® System Support Utility for Windows* software.
You can find the download link here:
  1. Download and launch SSU.exe.
  2. Check the box for "Everything."
  • When the scanning is complete, click "Next."
  • Click "Save."
  • Please send the saved file to us here or via email if you prefer.
Dean R.
LdBeth
Principiante
6.055 Visualizações
Thanks for the reply,
It is from Intel Optane Memory and Storage Management software, or the RST driver system service underlaying it.
I have an NVMe Optane Memory 32GB M.2 (not M10 Series), and an 1.9TB accelerated HDD. However the error message persists with the acceleration disabled.
The system info will be posted to here later today.
LdBeth
Principiante
6.044 Visualizações
Here is the system report generated by SSU
DeancR_Intel
Moderador
5.997 Visualizações
Hi LdBeth,
I will coordinate this to our engineers for further investigation.
Please do give us more time to this, we will get back to you possibly when we have the necessary information.
Dean R.
IntelSupport
Administrador
5.879 Visualizações
Hi LdBeth,
Please note due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help.
You may also find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html ) helpful to address your request.
Thank you for understanding.
Vikas
ManoranjanDas
Funcionário
5.848 Visualizações
Hi Qifan,
Greeting from Intel!
Kindly share the Intel Optane memory model details and confirm which drive is generating this error message.
Unfortunately, the Intel® OptaneTM Memory H10 has end of interactive support. Please refer to this link for more information about it. https://www.intel.com/content/www/us/en/support/articles/000024320/memory-and-storage.html
Thank you for your support and understanding!
Manoranjan.
Intel Customer Support
ManoranjanDas
Funcionário
5.783 Visualizações
Hello Qifan,
We are following up, just checking if you found the information we provided. Please confirm so we can continue assisting you.
Manoranjan.
LdBeth
Principiante
5.758 Visualizações
Manoranjan,
Thank you for the response, I understand the Optane Memory series has reached end of support. However, the error message is irrelevant to the Optane Memory, as completely disable and physically remove the Optane Memory from the system could still reproduce the same error so I'd guess the issue is with the RST driver itself not compatible with Windows 11 Dev Drive.
I'm reaching out only to see if there will be any future plan to release updates to RST driver for 11th gen Intel Core platforms and see if other users might have encountered same issue.
LdBeth
DeancR_Intel
Moderador
5.410 Visualizações
Hi LdBeth,
Apologies for the delay on my response. The latest drivers that we have are those available here:
Support for Intel® Rapid Storage Technology (Intel® RST) and any driver updates will be posted there in the future.
Also, please be advised that there are Intel drivers, and your OEM might have customizations specific to their product and it's best to check your OEM website for any driver updates.
Here's the link for your reference:
Support | iBUYPOWER®
ASRock > Support
Dean R.
DeancR_Intel
Moderador
5.286 Visualizações
Hi LdBeth,
I'm following up to find out if you experience any issues. I'm not able to get any response from you regarding the needed information.
Dean R.
DeancR_Intel
Moderador
5.176 Visualizações
Hi LdBeth,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
Responder
