Rapid Storage Technology
Intel® RST, RAID
2233 Discussions
Error instaling Intel RST - this platform is not supported
TKasp1
Intel Support Assistant is showing I should update Intel RST.
While installing I get error: this platform is not supported.
LeonWaksman
  1. Are you using Optane acceleration?
  2. What is the SATA mode in BIOS settings? It is RST or AHCI?
Leon
TKasp1
Thanks for answer
  1. My gut feeling answer is “No”. Never installed software with Optane option. Not sure how to check it for sure.
  2. Checked my BIOS and it actually has very few options. No options concerning SATA. Any other way to check it
BTW computer is HP Envy 17 (one of the older ones 17t-n100
LeonWaksman
1. Please download the Intel System Support Utility (SSU). Run the SSU scan and save the results. The .txt file with the results please attach to your post (use "paperclip", below the left bottom corner). In this report I can see if you have Optane Memory Module installed.
2. Since you computer is one of the older models, I think that it is even not compatible with Optane memory. The SATA mode you can see in BIOS settings > System Configuration tab > SATA Native Mode field. If it is set to "Enable" it means it is set to AHCI mode.
Leon
PBatt1
I have the same problem yet the Intel Driver and Support Assistant keeps telling me to update, but give the same incompatability message.
LeonWaksman
Hi @PBatt1​
  1. Although you have "the same" problem, however i suggest that you should open a thread of yours, rather than hijack this one. Your computer or system configuration is probably different, so the solution can be different.
  2. In addition, once you open a new thread, please attach to your a .txt file with the SSU report, rather than partial image of this report.
Leon
TKasp1
Put my reply in main thread. Thanks!
PBatt1
Thank you for your admonishment.
TKasp1
Thanks for the answer
  1. Atached
  2. Checked. Just five options under System configuration. None pertaining to SATA
LeonWaksman
  1. You are right, you don't need this RST driver at all. You have no Optane Memory installed. You have no RAID array neither. HP tends to install redundant software.
  2. Open the Device Manager, Storage Controllers section.
  3.  Right click on Intel Chipset SATA/PCIe RST Premium Controller and then click on Uninstall device (check the option "Delete the driver...")
  4. Open Apps and Features (Windows settings) and uninstall (if any) RST or Optane software.
Leon
TKasp1
hanks a lot.
I do not have such device installed. I have Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller. Should I get rid of that.
so I applied point no 2 only. Will see if this will stop the updates coming.
LeonWaksman
  1. You meant that you will uninstall the  Intel Chipset SATA/PCIe RST Premium Controller (para 2 and 3 i my post above)?
  2. Please inform what are the results.
Leon
TKasp1
  1. I would but it is not on the list of (see the attachment). Instead I have: Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller - should I uninstall this one?
LeonWaksman
No, do not uninstall the Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller. I was informed that this RST driver was provided in error and has been fixed in Download Center. Can you please run again the IDSA and check if this error persists?
Leon
Leonardo_C_Intel
Hello TKasp1
Thank you for posting in the Intel Community.
Thank you for bringing this to our attention. Our team has updated the driver detection as this driver was provided in error. When you re-scan with IDSA, you should not be offered an RST driver that isn't compatible with your system. We apologize for the inconvenience
Leonardo C.
IntelSupport
Community Manager
Hello TKasp1
we just released a new IDSA version today (20.7.26), canyou try rescanning one more time with IDSA (which should force the IDSA version updated in the process) and report back if you are still getting the message to update RST.
Leonardo C.
IntelSupport
Community Manager
Hello TKasp1
Have you been able to try the steps provided?
Leonardo C.
IntelSupport
Community Manager
Hello TKasp1
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Leonardo C.
