Rapid Storage Technology
Intel® RST, RAID
2253 Discussions
IRST accelerate option missing
PKroo
Hello world,
I'm trying to set up Smart Response Tech (or something like that) by using a SSD as cache for a HDD. But in the Inter Rapid Storage Technology program there's no button 'accelerate' (or anything similar); the help function also did not help.
All my drives are connected to the same controller (system report attached), and it's running in RAID mode. I want to accelerate the disk on port 0 (WD2001FASS-...) using the ssd on port 1 (KINGSTON ...60G).
The SSD is 56GB is size, and completely unallocated. I have already performed a low level format using diskpart's 'clean all' (when I open Windows' disk management it asks me to initialise the disk as either MBR or GPT, so I think the formatting worked).
The HDD is ~2TB, and contains one partition (Basic disk, MBR, NTFS) with flags Page File, Active, Primary Partition.
Motherboard chipset: H270
CPU: Intel i5-7600K kabylake
Please help, it's driving me up the wall...
EDIT: shrinking and expanding the partition on port 0 didn't help either
Message was edited by: Pitje
Hello Pitje,
Thank you for contacting the Intel community.
I'm sorry that it took me some time to come around to this post and to be able to help you.
Just make sure the SSD is unallocated as you already have mentioned above, your operating system needs to be installed with the BIOS set as RAID mode and download the latest IRST.
https://downloadcenter.intel.com/download/26361/Intel-Rapid-Storage-Technology-Intel-RST-RAID-Driver?product=55005 Intel® Rapid Storage Technology (Intel® RST) RAID Driver
I found and article that can be helpful for you, please check the following link:
https://www.tenforums.com/drivers-hardware/4478-guide-fix-acceleration-tab-button-missing-intel-rst.html https://www.tenforums.com/drivers-hardware/4478-guide-fix-acceleration-tab-button-missing-intel-rst.html
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan.
PKroo
thanks for the response, I'm not used to receiving any support for software whatsoever, so I'm really happy this forum is being monitored
I downloaded the drivers/IRST you linked, and reinstalled them. Didn't work.
Next i shrunk both my C: drive and my E: drive (which I want to accelerate). Didn't work either.
Growing the partitions again also did not help.
I rebooted every time before seeing if it helped.
The controller is in RAID mode.
Could I unplug the two drives I don't want to accelerate (including my system drive), and then enable acceleration from the BIOS?
I hope there's still some options left...
Pitje
Please leave some unallocated space at the end of the mechanical drive. I believe 100 MB should be enough but otherwise increase the amount and try again.
Actually, you can try setting the unallocated space as I have mentioned above but according with the Intel ark website the Intel® H270 Chipset does not support the Intel® Smart Response Technology, you can check here:
http://ark.intel.com/products/98090/Intel-H270-Chipset http://ark.intel.com/products/98090/Intel-H270-Chipset
Ivan.
PKroo
I'm feeling pretty stupid now, I can tell you that...
If I understand the promo-page (https://www-ssl.intel.com/content/www/us/en/architecture-and-technology/optane-memory.html Intel® Optane™ Memory) correctly Optane does roughly the same thing, but with a M2 ssd, right? Do you know whether it has to be a specific model?
Thanks for the help, I'll mark it as answered.
Pitje
AOroz4
I need some help here, I have the exact same problem, it is driving me crazy, mi processor does support IRST http://ark.intel.com/products/88967/Intel-Core-i7-6700HQ-Processor-6M-Cache-up-to-3_50-GHz?q=Core%20i7-6700HQ Intel® Core™ i7-6700HQ Processor (6M Cache, up to 3.50 GHz) Product Specifications
I don't know how to set my system in order to have the accelerate option available.
PKroo
Hi Zaggan,
what chipset does your motherboard have? Could you attach a system report (Under IRST's help function somewhere)? You might get a faster reply if you make your own topic, but I'm not sure what the nettiquette is on this forum.
Yes, it is similar to that, when combined with a large storage drive; the Intel® Optane™ memory M.2 module accelerates computer performance, while maintaining capacity.
Please bear in mind that this product has not been released yet and we still don't have information when it is going to be release but hopefully it will be soon.
By placing this new memory media between the processor and supported storage device, we are able to store frequently used data (programs) closer to the processor which allows the system to access this information more quickly. By pairing Intel® Optane™ Memory with slower storage devices (like HDDs, SATA SSDs), the PC user can get amazing responsiveness with high capacity local storage.
Ivan.
AOroz4
Informe del sistema
Información del sistema
Estado: Microsoft Windows 10 Pro
Versión del SO: 10.0.10586
Nombre del sistema: DESKTOP-MEC762L
Fabricante del sistema: Alienware
Modelo del sistema: Alienware 17 R4
Procesador: GenuineIntel Intel64 Family 6 Model 94 Stepping 3 2.601 GHz
BIOS: Alienware, 1.0.12
Tecnología de almacenamiento Intel® Rapid empresa
Kit instalado: 15.2.0.1020
Versión de la interfaz de usuario: 15.2.0.1020
Idioma: Español (México)
Versión de la ROM opcional de RAID: 15.2.1.2771
Versión del controlador: 15.2.0.1020
Versión de ISDI: 15.2.0.1020
Información del sistema de almacenamiento
Configuración de RAID
Información del hardware
Nombre de controladora:Intel Chipset SATA RAID Controller
Tipo:SATA
Modo:RAID
Número de puertos SATA: 3
Número de volúmenes: 0
Número de dispositivos de repuesto:0
Número de discos disponibles:2
Reconstrucción de la Conexión en Caliente:Desactivado
Fabricante:32902
Número de modelo:10274
Revisión de producto:49
Disco conectado directamente:170127422921
Disco conectado directamente:JR1000D31Z2LYE
Disco enControladora 0, Puerto 0
Estado: Normal
Tipo:SSD SATA
Tipo de ubicación:Interno
Uso: Disponible(s)
Tamaño: 119 GB
Disco del sistema: No
Caché de datos de disco: Activado
Colocación en cola de comandos: NCQ
Velocidad de transferencia: 6 Gb/s
Modelo: SanDisk X400 M.2 2280 128GB
Número de serie:170127422921
ID de dispositivo SCSI:0
Firmware: X4130012
Tamaño del sector físico: 512 bytes
Tamaño del sector lógico: 512 bytes
Disco enControladora 0, Puerto 3
Estado: Normal
Tipo:Disco SATA
Uso: Disponible(s)
Tamaño: 932 GB
Disco del sistema: Sí
Modelo: HGST HTS721010A9E630
Número de serie:JR1000D31Z2LYE
Firmware: JB0OA3W0
Tamaño del sector físico: 4096 bytes
Puerto vacio
Puerto: 0
Ubicación del puerto: Interno
System Report
System Information
OS name: Microsoft Windows 10 Pro
OS version: 10.0.10586
System name: DESKTOP-MEC762L
System manufacturer: Alienware
System model: Alienware 17 R4
Processor: GenuineIntel Intel64 Family 6 Model 94 Stepping 3 2.601 GHz
Intel® Rapid Storage Technology enterprise Information
Kit installed: 15.2.0.1020
User interface version: 15.2.0.1020
Language: English (United States)
RAID option ROM version: 15.2.1.2771
Driver version: 15.2.0.1020
ISDI version: 15.2.0.1020
Storage System Information
RAID Configuration
Hardware Information
Controller name: Intel Chipset SATA RAID Controller
Type: SATA
Mode: RAID
Number of SATA ports: 3
Number of volumes: 0
Number of spares: 0
Number of available disks: 2
Rebuild on Hot Plug: Disabled
Manufacturer: 32902
Model number: 10274
Product revision: 49
Direct attached disk: 170127422921
Direct attached disk: JR1000D31Z2LYE
Disk on Controller 0, Port 0
Status: Normal
Type: SATA SSD
Location type: Internal
Usage: Available
System disk: No
Disk data cache: Enabled
Command queuing: NCQ
Transfer rate: 6 Gb/s
Model: SanDisk X400 M.2 2280 128GB
Serial number: 170127422921
SCSI device ID: 0
Firmware: X4130012
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Disk on Controller 0, Port 3
Status: Normal
Type: SATA disk
Usage: Available
System disk: Yes
Model: HGST HTS721010A9E630
Serial number: JR1000D31Z2LYE
SCSI device ID: 0
Firmware: JB0OA3W0
Physical sector size: 4096 Bytes
Empty port
Port: 0
Port location: Internal
Since you have a laptop you best contact support is your computer manufacturer as they are more familiar with your system and how all the components interact with each other.
However, you can try installing the latest version, I know you already have it installed but try reinstalling it.
All you need to do is to enable drive acceleration in the Intel® Rapid Storage Technology.
Ivan.
AOroz4
Ivan, the option is not available, I can't see the button to accelerate, I know how it works since I have a laptop Dell Vostro which I have accelerated, and from Alienware support they told me to contant Intel
PKroo
If my google skills are still up to scratch, you should have either an Intel CM236 or Intel CM238 motherboard chipset. Both *should* support SRT.
1) is your SSD unallocated? This is something different than an empty partition.
2) What does the partitioning on your HDD look like? Could you change it such that there is ~200 MB free at the end of the disk? Again, a disk is something different than a partition in this context.
If you did both, and it still does not work, try a low-level format of the SSD.
PKroo
Actually, having a second look at your system report: Your SSD is too large. IIRC the maximum SSD size supported is 64GB.
AOroz4
As far as I've seen on the Internet, the maximum usable space is 64GB but the SSD can be any size, actually I've found that some people have accelerated their HDD with a 128GB SSD, using 64GB for acceleration and the rest as an extra storage space, on monday I will perform the low level format, the drive is unallocated, same monday I will upload a screenshot of the HDD partition so you can take a look.
Thank you for your contribution on this post and Zaggan your right the Intel Smart Response Technology can be configured to consume up to 64GB of space on an SSD and the extra space on SSDs larger than 64GB can still be accessed by the system.
Please remember that your BIOS needs to be set as raid mode and keep us posted how it goes after formatting your SSD.
Ivan.
AOroz4
already performed a low level format, did not worked at all, any more ideas?
Did you try leaving unallocated space at the end of the mechanical drive? I believe 100 MB should be enough but otherwise increase the amount and try again.
Ivan.
AOroz4
I did it already, I don't know if there is some extra configuration needed to leave the HDD accelerated with the SSD
The only way that this option is not available in the IRST is when RAID mode is not set in the BIOS.
If it is already set and the problem persists, try installing the chipset driver, you can try the https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility-?product=98087 Intel® generic driver
Was this working fine before? What changes were made when this started to happen? If nothing has been change and this started to happen suddenly I suggest you to contact your computer manufacturer for support as they are more familiar with your system and how the components interact with each other.
Ivan.
mark66collins
I had the same issue. I tried the shrink/expand too, and that did not work.
There's a tab (the second tab) on the Intel RST utility named "Manage". Highlight the cache disk and then the option "clear metadata".  Then the "Acceleration" option returns.
