Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
Install Intel Rapid Storage Technology Driver on Windows 10 (ASUS P8Z77-M PRO mobo)
GLa_R
I can't install Intel RST on Win 10 64 bit, on my desktop with ASUS P8Z77-M PRO mobo. I have the lastest BIOS fw and ASMEDIA Ver. 3160
Previously, I had Intel Rapid Storage 13.1 (and it didn't report any feature to set a SSD disk as cache), so I remove it and I tried to install 14.8.0.1042, but It fails with the error below.
Some additional info:
1) from windows manager I saq: IDE ATA/ATAPI controllers
CTRL Intel Series/C216 Chipset Family SATA AHCI Controller before uninstall Intel RST version 1.3.1, now I see: Microsoft Standard SATA AHCI Controller 10.0.10586.0
but I have also as controllers: ASmedia 106x SATA CRTL 3.1.6.0 and MS Storage Space controller
2) AHCI is enabled from OS and Bios configuration
3) SATA MODE SELECTION is SATA from BIOS
2016:04:04 10:58:41:090: Checking .NET version...
2016:04:04 10:58:41:090: Expected version: v2.0.50727
2016:04:04 10:58:41:090: Found registry key for the expected .NET version.
2016:04:04 10:58:41:090: Expected version: v3.0
2016:04:04 10:58:41:090: Expected version: v3.5
2016:04:04 10:58:41:090: Expected version: v4\Client
2016:04:04 10:58:41:091: Found registry key for the expected .NET version.
2016:04:04 10:58:41:091: Checking .NET version...
2016:04:04 10:58:41:091: Expected version: v4\Full
2016:04:04 10:58:41:091: Expected version: v4.5\Client
2016:04:04 10:58:41:091: Looking for .NET version 4.5 or above
2016:04:04 10:58:41:091: Found version: 4.6.01038
2016:04:04 10:58:41:091: Expected version: v4.5\Full
2016:04:04 10:58:41:091: Loading saved properties
2016:04:04 10:58:41:098: Effective command line: "C:\Users\flex\Desktop\RST update\SetupRST\SetupRST.exe"
2016:04:04 10:58:41:098: >>> Log start
2016:04:04 10:58:41:098: Mutex with given name doesn't exist. Creating new one.
2016:04:04 10:58:41:099: Obtained mutex succesfully.
2016:04:04 10:58:41:099: Single-instance mutex has been obtained
2016:04:04 10:58:41:099: Core version: 2.5.53
2016:04:04 10:58:41:100: Setup version: 2.3.1.0
2016:04:04 10:58:41:100: Command line: "C:\Users\flex\Desktop\RST update\SetupRST\SetupRST.exe"
2016:04:04 10:58:41:100: OS data: 6-2-1-0 64-bit
2016:04:04 10:58:41:100: System up time: 128 sec
2016:04:04 10:58:41:100: Reboot pending: No
2016:04:04 10:58:41:100: Current UI language: 0409
2016:04:04 10:58:41:101: Language folder: C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp
2016:04:04 10:58:41:112: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\ar-SA\IntelCommon.dll. Lang 0401. Rank 0
2016:04:04 10:58:41:122: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\cs-CZ\IntelCommon.dll. Lang 0405. Rank 0
2016:04:04 10:58:41:133: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\da-DK\IntelCommon.dll. Lang 0406. Rank 0
2016:04:04 10:58:41:143: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\de-DE\IntelCommon.dll. Lang 0407. Rank 0
2016:04:04 10:58:41:153: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\el-GR\IntelCommon.dll. Lang 0408. Rank 0
2016:04:04 10:58:41:163: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
2016:04:04 10:58:41:173: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\es-ES\IntelCommon.dll. Lang 0C0A. Rank 0
2016:04:04 10:58:41:183: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\fi-FI\IntelCommon.dll. Lang 040B. Rank 0
2016:04:04 10:58:41:193: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\fr-FR\IntelCommon.dll. Lang 040C. Rank 0
2016:04:04 10:58:41:203: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\he-IL\IntelCommon.dll. Lang 040D. Rank 0
2016:04:04 10:58:41:214: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\hu-HU\IntelCommon.dll. Lang 040E. Rank 0
2016:04:04 10:58:41:224: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\it-IT\IntelCommon.dll. Lang 0410. Rank 0
2016:04:04 10:58:41:234: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\ja-JP\IntelCommon.dll. Lang 0411. Rank 0
2016:04:04 10:58:41:243: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\ko-KR\IntelCommon.dll. Lang 0412. Rank 0
2016:04:04 10:58:41:254: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\nb-NO\IntelCommon.dll. Lang 0414. Rank 0
2016:04:04 10:58:41:263: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\nl-NL\IntelCommon.dll. Lang 0413. Rank 0
2016:04:04 10:58:41:274: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\pl-PL\IntelCommon.dll. Lang 0415. Rank 0
2016:04:04 10:58:41:284: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\pt-BR\IntelCommon.dll. Lang 0416. Rank 0
2016:04:04 10:58:41:294: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\pt-PT\IntelCommon.dll. Lang 0816. Rank 0
2016:04:04 10:58:41:304: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\ru-RU\IntelCommon.dll. Lang 0419. Rank 0
2016:04:04 10:58:41:314: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\sk-SK\IntelCommon.dll. Lang 041B. Rank 0
2016:04:04 10:58:41:324: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\sv-SE\IntelCommon.dll. Lang 041D. Rank 0
2016:04:04 10:58:41:335: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\th-TH\IntelCommon.dll. Lang 041E. Rank 0
2016:04:04 10:58:41:345: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp\tr-TR\IntelCommon.dll. Lang 041F. Rank 0
2016:04:04 10:58:41:355: Found C:\Users\flex\AppData\Local\Temp\IIFF70D.tmp&#92...
Amy_C_Intel
Hello, PeppeLaRosa:
Please try installing the following version https://downloadcenter.intel.com/download/25771/-Intel-Rapid-Storage-Technology-Enterprise-NVMe-Intel-RSTe-NVMe-RAID-Driver Download Intel® Rapid Storage Technology Enterprise NVMe (Intel® RSTe NVMe) RAID Driver.
GLa_R
Hi Amy_Intel,
it doesn't match the minimum requirements for installing. Checking the documentation, it requires a Xeon E5 processor while I have a Intel Core i5 3570K
BR
Peppe
Amy_C_Intel
Is your system set to RAID or HCI?
GLa_R
Hi Amy_Intel,
it was AHCI, after moving it to RAID the Intel software worked,but the accelerate menu button is still missing as when I installed version 13.1.
It's strange because the SSD (Disk 1 in the image below) is initializated as MBR without any partition as required.
Any idea ?
Amy_C_Intel
I just want to confirm, did you set your system from AHCI to RAID without installing the operating system first?
GLa_R
Hi Amy_Intel,
yes right, as workaround I ran the OS in emergency mode in order to fix drivers. After that it booted properly without error in RAID configuration.
BR
Giuseppe
Amy_C_Intel
With the workaround, are you able to see the accelerate menu button? Otherwise, you will have to reinstall the operating system.
GLa_R
Hi Amy_Intel,
that's the problem: no accelerate menu available.
Unfortunately, reinstall the OS is not an option at the moment, many thanks for the support.
BR
Giuseppe
Amy_C_Intel
I understand.
If you need further assistance let us know.
SJade
I have faced this Sata ahci controller Driver but latter i update the driver and its working fine Download Sata Ahci
