Rapid Storage Technology
Intel® RST, RAID
2188 Discussions
Message d'erreur Impossible de charger la DLL i A Storafs service Api.dll le module spécifié est introuvable exeption de H result 0X80070
SSt-A
LeonWaksman
I can't understand your question. See this page for explanation about different Optane error messages: https://www.intel.com/content/www/us/en/support/articles/000024113/memory-and-storage/intel-optane-memory.html
Leon
SSt-A
Whenever the computer is running this error message appears. What should I do to make this message disappear?
I checked the error codes but I can not find this code in the information where you directed me.
Thank you for your concern
Abigail_G_Intel
Hello SSt-A,
Thank you for posting on our Intel Community.
Note: Community support is offered only in the English language. We are using the translator tool on this website to translate your information.
In order to have more information about the issue that you are experiencing, please provide me with the following information:
  1. Are you able to boot into Windows*?
  2. How often does the error occur?
  3. Could you provide me with your hardware and software issue related set up?
  4. Is the error exactly "Unable to load DDL (Database Definition Language) 'i A Storafs service Api .dll' the specified module could not be found (Exception from Hresult:0x800700)"?
Abigail G
Under Contract to Intel Corporation.
SSt-A
Question 1 Oui je peux redémarrer Windows pas de problème. L’ordinateur fonctionne très bien . Question 2 À chaque fois que je me sers de mon ordinateur Question 3 Asus VivoBook Pro Question 4 Ce n’est qu’un message (notification )qui apparait tout le temps , il n’y a rien qui fait défaut au point vu logiciel ou autre.
Abigail_G_Intel
Hello SSt-A,
Thank you for the response and the information.
I would like to clarify the information about the error in order to make sure that we can provide you with an answer or direct you to the best support for this issue.
  • Please provide the Intel® Rapid Storage Technology (Intel® RST) report:
  1. Open the Intel Rapid Storage Technology user interface (Start > Programs > Intel > Intel® Rapid Storage Technology).
  2. Click the Help icon.
  3. Click the System Report icon.
  4. Click Save.
  1. Click the menu where it says summary to change to Detailed View.
  2. To save your scan, click Next and click Save. You can save the file to any accessible location on your computer.
  3. Please attach the document to the next post.
Abigail G
SSt-A
Voir le rapport ci joint j'espère que j'ai fait cela comme il le faut. Merci
Abigail_G_Intel
Hello SSt-A,
Thank you for the response and the information provided.
Checking the report that you have provided I was not able to see any error of failure. Please provide me with the Intel® Rapid Storage Technology (Intel® RST) report:
  4. Click Save.
Also, I would like to ask you if you have tried to contact the computer manufacturer to check if someone else has reported the same issue?
Abigail G
SSt-A
Quand j'ouvre Intel Rapid Storage voilà ce que je vois
Abigail_G_Intel
Hello SSt-A,
Have you tried installing the latest version for Intel® RST provided by your OEM (Original Equipment Manufacturer)?
I was able to see the downloads available on the following link:
https://www.asus.com/us/Laptops/ASUS-VivoBook-Pro-15-N580GD/HelpDesk_Download/
Under "Others" categorization.
Note: Intel recommends that end users utilize driver updates provided by their system manufacturer/provider or via Windows Update to eliminate the potential impact caused by loading non-customized drivers. System manufacturers regularly customize Intel generic drivers to meet the needs of their specific system design.
If the issue persists after installing the OEM version, please test downloading the latest version provided by Intel:
https://downloadcenter.intel.com/download/28650/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005
Abigail G
SSt-A
Others
Version V30.100.1727.1
2019/05/20173.59 KBytes
Intel(R) Serial IO SPI Driver
DOWNLOAD
2019/05/20226.72 KBytes
Intel(R) Serial IO UART Driver
DOWNLOAD
Version V16.8.0.1000
2019/05/063.75 MBytes
Intel Rapid Storage Technology driver
DOWNLOAD
Version V1.0.0.13
2019/03/13617.16 KBytes
Focal Fingerprint driver and utility
DOWNLOAD
Version V4.5.1001.10002
2019/03/121 MBytes
ASUS FingerPrint
An application provides fingerprint authentication for Windows operating system.
DOWNLOAD
Version V1803.12.0.1093
2019/03/1268.4 MBytes
Intel Management Engine Interface
DOWNLOAD
Version V16.7.9.1027
2018/11/2618.09 MBytes
DOWNLOAD
Version V16.7.0.1009
2018/11/223.43 MBytes
DOWNLOAD
Version V1805.12.0.1097
2018/09/1168.4 MBytes
DOWNLOAD
Version V8.4.10500.5526
2018/08/077.92 MBytes
Intel® Dynamic Platform and Thermal Framework Driver
DOWNLOAD
Version V3010017271
2018/08/072 MBytes
Intel Serial IO controller driver
DOWNLOAD
Version V1.0.0.15
2018/08/07616.75 KBytes
DOWNLOAD
Version V16.0.2.1086
2018/07/1718.99 MBytes
DOWNLOAD
Version V4.5.1001.10202
2018/05/301.29 MBytes
ASUS FingerPrint
DOWNLOAD
Utilities
LAQUELLE DOIS CHOISIR DANS (AUTRE) CE N'EST PAS MOI QUI A INSTALLÉ LA VERSION QUI EST DANS MON ORDINATEUR. C'EST LE MAGASIN QUI A FAIT CELA.
jE LEUR AI DEMANDÉ DE CORRIGER ET IL M'ON DIT D'ARRÊTER LES NOTIFICATIONS DANS L'ORDINATEUR. HUMMM! J'AI PAS AIMÉ LA RÉPONSE ALORS J'ESSAIE DE ME DÉBROUILLER AUTREMENT .
JE VAIS Y ARRIVER ET JE VAIS ALLER LEUR MONTRER COMMENT CA MARCHE . HI HI
SSt-A
SI CELA NE FONCTIONNE PAS , JE VAIS INSTALLER LA PROCHAINE POUR CORRIGER LE TOUT . JE VOUS REMERCIE DE VOTRE PATIENCE ET JE DONNERAI VOTRE NOM
SYLVIE
Abigail_G_Intel
Hello SSt-A,
I am glad to know that you were able to find the root of the issue and you will contact them in order to correct it.
I will close this inquiry now. If you need further assistance, please post a new question.
Abigail G
SSt-A
Vous n'avez pas répondu à ma dernière question . Quelle version dois-je choisir dans la liste que je vous ai envoyé précédemment.
Je sais pas trop celle qui va corriger le problème après si ca ne marche pas j’irai voir le marchand .
SVP et merci de votre patience
Abigail_G_Intel
Hello SSt-A,
I am sorry, the version that you will need to install is the latest driver for "Intel Rapid Storage Technology driver" listed there, version V16.8.0.1000. If the issue persists after this installation we would recommend you to get in contact with the computer manufacturer in order to know if the issue is related to another software.
Abigail G
