Rapid Storage Technology
Intel® RST, RAID
2254 Discussions
Intel RST F6 driver package
RMB9
I am trying to get the Intel RST F6 Driver Package v20.2.1.1016 for Z890 RAID 1 Non-VMD.
I need specifically the F6 driver files: iaStorVD.inf, iaStorVD.sys and iaStorVD.cat.
Or, the Full RST installer: SetupRST.exe
Can anyone point me to the source to get these?
I think it would be best from Intel's Driver source.
Thank you in advance!
Mike_Intel
Hello RMB9,
  1. Can you tell me more about the issue that you encounter? What is the reason why you are asking for the F6 driver?
  2. What is the brand and model of your system?
  3. If you are having RAID issues, kindly send some screenshots for me to check.
  4. What are the troubleshooting steps that you tried so far?
Michael L.
RMB9
Michael L.
Thank you for you reply.
I will generate a report as best as possible and get it to you in a day or two.
I am working on other technical issues with another system at present.
Thank you!!!!
RMB9
RMB9
Author: RMB9
Topic: RAID 1 Driver Integration and Windows 11 Pro Installation on Intel RST Controller (Device ID 7D0B, Z890 Chipset)
1. System Context
• Hardware: Desktop board with Intel Z890 chipset, RAID 1 array configured in BIOS.
• Controller: Intel RST (Rapid Storage Technology) controller, PCI ID 7D0B.
• Target OS: Windows 11 Pro (clean install).
• Install Goal: Lean, telemetry‑free build with RAID stability and reproducibility.
2. Driver Preparation
• Downloaded official Intel RST package directly from Intel support site.
• Manually extracted installer to ensure presence of required files:
• (driver binding instructions)
• (driver binary)
• (catalog/signature file)
• Verified file integrity after suspecting corruption in earlier USB prep.
• Rebuilt driver USB with alphabetized folder structure for clarity.
3. INF Modification
• Identified mismatch between RAID controller PCI ID (7D0B) and supported IDs in stock INF.
• Manually patched INF to include correct binding for 7D0B.
• Applied signature enforcement workaround:
• Disabled driver signature checks temporarily during setup.
• Ensured reproducibility by documenting exact INF edits.
4. Windows Setup Execution
• Booted into Windows 11 Pro installer.
• Used Load Driver option to inject patched Intel RST driver from USB.
• RAID volume detected successfully after driver load.
• Bypassed forced internet setup with command:
• Enabled offline installation.
• Created local account without Microsoft sign‑in requirement.
5. Post‑Install Configuration
• Telemetry Control:
• Disabled telemetry services (e.g., Connected User Experiences, Diagnostic Tracking).
• Removed scheduled tasks related to data collection.
• Cleaned registry hooks for telemetry persistence.
• Driver Hub Management:
• Allowed ASUS Driver Hub auto‑install for chipset essentials.
• Pruned optional utilities (e.g., monitoring tools, update agents) to maintain lean profile.
• Validation:
• RAID volume confirmed stable in Disk Management.
• No phantom devices or driver conflicts detected.
• Multi‑monitor setup tested; refresh rates aligned without flicker.
6. Key Challenges & Solutions
• Driver Binding: Stock INF did not recognize RAID controller → solved via manual INF patch.
• Signature Enforcement: Windows blocked modified INF → solved with enforcement workaround.
• Installer Workflow: Forced online setup → bypassed with .
• Telemetry Persistence: Surviving scheduled tasks → solved with registry and task cleanup.
• Driver Hub Bloat: Auto‑install of unnecessary utilities → solved with selective pruning.
7. Conclusion
This workflow demonstrates reproducible steps for integrating Intel RAID drivers into Windows 11 Pro setup on unsupported controller IDs. The process ensures RAID stability while maintaining a lean, telemetry‑free environment. Documentation of INF edits and enforcement workarounds provides a clear path for replication and troubleshooting.
AlHill
You know, before chatgpt and AI, the word "conclusion" was rarely used.
[CoPilot is a virus]
Mike_Intel
Hello RMB9,
Thank you for the update.
Let me share this link for the procedure on how to install F6 driver during the OS installation and kindly tell me if you follow these steps:
Unable to Detect the Drive When Installing a New Windows* OS on a...
After checking the steps above, can you further elaborate on the issue that you raised and the help that you need from me.
By the way, you also mentioned unsupported controller ID's and since it is unsupported, you may need other workarounds since it is unsupported.
Michael L.
RMB9
I was simply trying to get the Intel RST F6 Driver Package v20.2.1.1016 for Z890 RAID 1 Non-VMD.
I specfically needed the .inf file so that I could get Windows to recognize my RAID 1 configuration so I can could do a fresh intallation of Windows on my two ssd configured in RAID 1.  Without that file Windows does not see my RAID 1 and without that I can't point the fresh install to my RAID 1 ssds.
I could not find the RST F6 Driver Package on the Intel Driver website.
n_scott_pearson
You should be able to open the standard package executable in an app like 7-Zip and extract the drivers and associated .INF files. Have you tried this?
neverhood
I ran into the same issue after my HP laptop just decided to stop working and I am trying to reinstall Win11.
The main drive is just not visible. Extracted the .inf files from the SetupRST exe yet the Win11 Setup cannot install them even if I can see them as:
Intel RST VMD Controller 9A0B | {path}\VMD\iaStorVD.inf
Intel RST VMD Managed Controller 09AB | {path}\VMD\iaStorVD.inf
The Win11 Install button is greyed out.
