Yesterday, after updating my Visual studio 2019 to professional edition then rebooting my win 10 box, I noticed that the machine was responding very slowly, then I discovered that Intel RST Service is not running, I went to services and started it several times as it stops after 30 seconds. I event viewer I have the following messages:
1 -
Faulting application name: IAStorUI.exe, version: 17.2.11.1033, time stamp: 0x5cd1f4fb
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1202, time stamp: 0xc9db1934
Exception code: 0xe0434352
Fault offset: 0x0000000000034f99
Faulting process id: 0x5cf0
Faulting application start time: 0x01d7d53db97ea0b8
Faulting application path: C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorUI.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: 10f0be07-5910-4a4b-a62e-bad3db6b5db2
Faulting package full name:
Faulting package-relative application ID:
2 -
Application: IAStorUI.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at <Module>.IsiSessionOpen(UInt32*)
at PsiData.PsiDataSource.Load(System.Collections.Generic.Dictionary`2<Int32,System.Object> ByRef, Boolean)
at PSI.PsiSystemDataModel.LoadDriverData(Int32)
at PSI.PsiSystemDataModel.CreateStaticDataModel()
at PSI.PsiSystemDataModel..cctor()
3-
Fault bucket 1284832326785615289, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: IAStorUI.exe
P2: 17.2.11.1033
P3: 5cd1f4fb
P4: PsiData
P5: 17.2.11.1033
P6: 5cd1f3c6
P7: 3b6
P8: 1f
P9: System.AccessViolationException
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WEREEB8.tmp.mdmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER687.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2F0F.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2F1E.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2F5E.tmp.txt
What ios the issue and how it can be fixed? thanks
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
