Rapid Storage Technology
Intel® RST, RAID
2223 Discussions
Intel RST gets BSoD IRLQ not less or equal on windows 10 FastStartup
FG
If anyone is interested, newer Intel RST 16.0.2.1086 fixed this problem.
This was happening on my Laptop MSI GT70-0NC running Windows 10 x64 Ver 1709 and also after upgrading to Windows 10 x64 Ver 1803 build 17134.1
Here is the configuration:
BIOS level is E1762IMS.30U, 16GB RAM, Sata array Raid 0 60+60GB, Sata Hitachi HDD 699GB, External Sata WD Mybook 1TB.
Failing with Intel RST level 15.8.1.1007.
The failure does not occur on Restart only on Fast Startup after a shutdown and only with a specific sequence.
Turning off Fast Startup in the windows control panel is a workaround that hides the bug.
With Fast Startup turned on the BSoD occurs every time the laptop is powered up after a shutdown and after turning off power to the External Sata Drive.
If the External Sata drive power is left on the bug may not show.
I think I isolated the problem to the Intel Rapid Storage Technology program so I downloaded the latest version that I found from the Intel support site, that fixed my problem.
Failing version was 15.8.1.1007 (BSoD IRLQ not Less Or Equal on Fast Startup ).
Woking version is 16.0.2.1086 (Finally no more BSoD on Fast Startup)
fggIB: Thank you very much for providing that feedback, we really appreciate that and we are sure this information will be very useful for all the peers viewing this thread.
Intel
