Rapid Storage Technology
Intel® RST, RAID
2207 Discussions
Intel Rapid Storage Technology IAStorUI.exe
ber999
Good morning,
who please can explain what does the term "Interner freier Anschluss 4" (internal free port 4)  on the figure attached to this message mean?
And, on which tab depicted by RWEverything can I find the corresponding information to this port 4?
I want to find out why NVMe SSD's in the internal SSD slot is no longer recognized by the Bios.
Thank you very much.
David_G_Intel
Hello ber999
Thank you for posting on the Intel️® communities.
Please share with us the results of the Provide the Intel® System Support Utility (Intel® SSU)
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
David G
Intel Customer Support Technician
David_G_Intel
Hello ber999
David G.
ber999
Good morning,
thank you very much. Result file is attached.
David_G_Intel
Hello ber999
We are working on this request, updates will be posted on this thread.
David G
ber999
Good afternoon,
Hardinfo running on Ubuntu brought the following results:
PCI Devices
Host bridge
Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
PCI bridge
Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07) (prog-if 00 [Normal decode])
VGA compatible controller
Intel Corporation UHD Graphics 630 (Mobile) (prog-if 00 [VGA controller])
Signal processing controller
Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 07)
Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
USB controller
Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10) (prog-if 30 [XHCI])
RAM memory
Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
Network controller
Intel Corporation Wireless-AC 9560 [Jefferson Peak] (rev 10)
Communication controller
Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
RAID bus controller
Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 10)
PCI bridge
Intel Corporation Cannon Lake PCH PCI Express Root Port #14 (rev f0) (prog-if 00 [Normal decode])
PCI bridge
Intel Corporation Cannon Lake PCH PCI Express Root Port #16 (rev f0) (prog-if 00 [Normal decode])
ISA bridge
Intel Corporation HM470 Chipset LPC/eSPI Controller (rev 10)
Audio device
Intel Corporation Cannon Lake PCH cAVS (rev 10)
SMBus
Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
Best regards
David_G_Intel
Hello ber999
Thank you for your patience. After checking the information provided, we noticed there are four partitions on your drive. To explain this internal port 4, this is because the RST detects the partitions. There is nothing wrong with the unit.
Additionally, the RST detects the amount of free SATA ports available but unfortunately, the OEM does not provide enough information to give more information about the computer specs.
For the other issue (SSD no longer recognized), that you will have to check with the OEM since this is BIOS related.
David G
ber999
Good afternoon,
I have two motherboards
[Motherboard]
Motherboard Model:
GIGABYTE AERO 15WV8
Motherboard Chipset:
Intel HM370 (Cannon Lake-H)
Motherboard Slots:
4xPCI Express x1, 2xPCI Express x4, 1xPCI Express x16
PCI Express Version Supported:
v3.0
USB Version Supported:
v3.1
[BIOS]
BIOS Manufacturer:
American Megatrends Inc.
BIOS Date:
09/14/2018
BIOS Version:
FB08
UEFI BIOS:
Capable
Super-IO/LPC Chip:
ITE IT8587E
And
Motherboard Model:
HP 84ED
Motherboard Slots:
2xPCI Express x1, 1xPCI Express x8, 1xPCI Express x16
v3.0
v3.1
[BIOS]
BIOS Manufacturer:
AMI
BIOS Date:
12/10/2020
BIOS Version:
F.30
UEFI BIOS:
Capable
Super-IO/LPC Chip:
ITE IT8987
In the treatise „Intel Optane Limited to Kaby Lake 7th Gen Intel Core Processors” Intel Optane Limited to Kaby Lake 7th Gen Intel Core Processors - Custom PC Review, I found a limitation as follows:
Begin citation ----------------
Pulled directly from the Optane mini-site, here’s the breakdown of what you need:
  1. 7th Generation Intel Core Processor (Kaby Lake)
  2. Intel 200 Series Chipset
  3. M.2 2280-S1-B-M or M.2 2242-S1-B-M on a PCH Remapped PCIe Controller in a x2 or x4 configuration with B-M keys that meet NVMe Spec 1.1
  4. System that supports Intel RST 15.5
End citation ------------------
The HP 84ED motherboard has a 1xPCI Express x8 slot, however neither x2 nor x4 configuration as stated in the requirements of the treatise (see above).
As a consequence, should be the HP 84ED board suitable for the Optane technology or not?
n_scott_pearson
There is nothing in the data, assertions or (IMHO, silly) citation that you have included that would allow us to determine whether or not this board supports the use of an Optane module. What you need to do is go into BIOS Setup and check whether the SATA Mode parameter supports an Optane setting. If it only supports AHCI and RAID, then you know that it doesn't support the use of an Optane module.
…S
ber999
Thank you very much. I agree with you. The problem is not Optane related. Coud you please move this thread to the appropriate group of processor related issues?
I have investigated the issue further and finally found out that the UEFI Firmware is preventing not only the use of other than HP distributed NVMe SSDs but every NVMe SSD in the slot affected.
The initiating incident was that had replaced the original SSD in the slot by a cloned SSD with larger capacity on which unfortunately the Efi partition was missing and then tried to boot the notebook and got an error message due to the situation.
After that, every attempt to boot the notebook from a SSD in the slot in question failed with the same error message.
Consequently, I have installed the Windows 10 system on the existing HDD in the SATA port, which brought serious performances losses.
Nevertheless, the investigation of the machine revealed that the Uefi hardware initialization which runs at the beginning of the boot process does not assign the NVMe SSD to the correct bus position PCI Express x8 Bus #1 [J6B2], because the Graphics card NVIDIA GeForce GTX 1050 Ti [HP] is assigned th this bus position now (see below).
For the Graphics card NVIDIA GeForce GTX 1050 Ti [HP] is the PCI Express x16 slot appropriate because of is matching width (x16 and not x8).
As the Uefi hardware-initialization-procedure does not assign the NVMe SSD now, the NVMe SSD hardware cannot be found by any operating system.
The Hwinfo64 report delivers the following results for my HP Pavilion:
  1. in the motherboard section
Motherboard Slots:
  1. in the bus section
[General Information]
Device Name:
Original Device Name:
NVIDIA GeForce GTX 1050 Ti (GP107M)
Device Class:
VGA Compatible Adapter
Revision ID:
A1
PCI Address (Bus: Device:
Function) Number:
1:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_10DE&DEV_1C8C&SUBSYS_84ED103C&REV_A1
[PCI Express]
Version:
3.0
Maximum Link Width:
16x
Current Link Width:
8x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
2.5 GT/s
Device/Port Type:
PCI Express Endpoint
Slot Implemented:
No
Emergency Power Reduction:
Not Supported
Active State Power Management (ASPM) Support:
L0s and L1
Active State Power Management (ASPM) Status:
L0s and L1 Entry
L0s Exit Latency:
256 - 512 ns
L1 Exit Latency:
2 - 4 us
Maximum Payload Size Supported:
256 bytes
Maximum Payload Size:
256 bytes
Resizable BAR Support:
Not Supported
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
Memory Base Address 0
63000000
Memory Base Address 1
50000000
Memory Base Address 3
60000000
I/O Base Address 5
0
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Fast Back-to-Back Transactions:
Not Capable
[Driver Information]
Driver Manufacturer:
NVIDIA
Driver Description:
Driver Provider:
NVIDIA
Driver Version:
27.21.14.6627 (GeForce 466.27)
Driver Date:
23-Apr-2021
DCH/UWD Driver:
Capable
DeviceInstanceId
PCI\VEN_10DE&DEV_1C8C&SUBSYS_84ED103C&REV_A1\4&33ECA368&0&0008
Location Paths
PCIROOT(0)#PCI(0100)#PCI(0000)
The PCI Express bus enumeration ends with #3 and the NVMe PCIe SSD controller is not listed.
However, a Hwinfo64 report of a comparable board can be found on the Internet.
There, an NVMe PCIe SSD controller is listed in the Bus section (see below) under PCI Express x4.
PCI Express x4 Bus #4
Samsung NVMe PCIe SSD Controller
Device Name:
Samsung Electronics NVMe PCIe SSD Controller
Device Class:
NVMe Controller
Revision ID:
0
PCI Address (Bus: Device: Function) Number:
4:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_144D&DEV_A808&SUBSYS_A801144D&REV_00
[PCI Express]
Version:
3.0
Maximum Link Width:
4x
Current Link Width:
4x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
8.0 GT/s
Device/Port Type:
Slot Implemented:
No
Not Supported
L1
L1 Entry
L0s Exit Latency:
>4 us
L1 Exit Latency:
32 - 64 us
256 bytes
256 bytes
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
AD200000
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Not Capable
Standard NVM Express Controller
Driver Description:
Driver Provider:
Microsoft
Driver Version:
10.0.19041.488
Driver Date:
21-Jun-2006
DeviceInstanceId
PCI\VEN_144D&DEV_A808&SUBSYS_A801144D&REV_00\4&CDF9F35&0&00DC
Location Paths
PCIROOT(0)#PCI(1B04)#PCI(0000)
My HP Pavilion, on the other hand, does not have a PCI Express x4 slot, but it does have a PCI Express x8 slot. According to the Hwinfo64 report of my HP Pavilion notebook, the graphics card NVIDIA GeForce GTX 1050 Ti (GP107M) sits in the PCI Express x8 slot. Specified for this graphics card is x4.
Maximum Link Width:
16x
In the Hwinfo64 report of the board used for comparison, the graphics card is attached to the PCI Express x16 bus #1 (see below) as listed in the Bus section, i.e. in the correct place (16 lanes).
PCI Express x16 Bus #1
NVIDIA GeForce GTX 1060 [GIGABYTE]
Device Name:
NVIDIA GeForce GTX 1060 (GP106M/N17P-G1)
Device Class:
Revision ID:
A1
PCI Address (Bus:Device:Function) Number:
1:0:0
PCI Latency Timer:
0
Hardware ID:
PCI\VEN_10DE&DEV_1C20&SUBSYS_16521458&REV_A1
Version:
3.0
Maximum Link Width:
16x
Current Link Width:
16x
Maximum Link Speed:
8.0 GT/s
Current Link Speed:
2.5 GT/s
Device/Port Type:
Slot Implemented:
No
Not Supported
L0s and L1
L0s and L1 Entry
L0s Exit Latency:
256 - 512 ns
L1 Exit Latency:
8 - 16 us
256 bytes
256 bytes
[System Resources]
Interrupt Line:
N/A
Interrupt Pin:
INTA#
AC000000
80000000
90000000
I/O Base Address 5
0
[Features]
Bus Mastering:
Enabled
Running At 66 MHz:
Not Capable
Not Capable
NVIDIA
Driver Description:
Driver Provider:
NVIDIA
Driver Version:
27.21.14.5167 (GeForce 451.67)
Driver Date:
05-Jul-2020
DCH/UWD Driver:
Capable
DeviceInstanceId
PCI\VEN_10DE&DEV_1C20&SUBSYS_16521458&REV_A1\4&DAED9F9&0&0008
Location Paths
In the System Buses section of the SiSoft Sandra report of my Pavilion notebook (see below), there is a warning 1204 at the end. Possibly, the reference there to the higher maximum supported speed is due to the lower number of lanes (8 in the bus instead of 16).
SiSoftware Sandra Systembusse
Systembusse
Schnittstellenversion: 2.30
PCI Busse: 4
PCIe Busse: 3
Systembus
Typ: PCI
Gerätenummer: 0
Multiplikator: 1x
Systembus
Typ: PCIe 3.0 x8 2.5Gbps
Gerätenummer: 1
Multiplikator: 3x
Bridge: Intel Core6 (Skylake) PCIe Controller (x16)
Systembus
Typ: PCIe 3.0 x1 2.5Gbps
Gerätenummer: 2
Multiplikator: 3x
Bridge: Intel ICH300 (Cannon Point) PCI Express Root Port #14
Gerät mit Anschluss verbunden: HP RTL8168/8111 PCI-E Gigabit Ethernet NIC
Systembus
Gerätenummer: 3
Multiplikator: 3x
Bridge: Intel ICH300 (Cannon Point) PCI Express Root Port #16
Gerät mit Anschluss verbunden: HP RTS522A PCI Express Card Reader
Leistungstipps
Warning 1204: Speed is below the maximum supported speed. The device may be in power-saving mode.
Tip 3: Press Enter or double-click on a tip to find out more information.
As the NVIDIA graphics card is soldered directly on the motherboard, there is, for test purposes, no possibility to disconnect the NVIDIA graphics card electrically.
n_scott_pearson
So what are you asking us to answer? It sounds like this HP system's BIOS is horribly, horribly screwed up and you need to be talking to them. No surprise; I consider both HP and Dell to be run by total slimebuckets and they doing nothing but rob their customers blind - including making them pay for support and the fixing of the bugs their BIOS (etc.) should have never had.
There I go preaching again. Off my soapbox now (and again)...
